Torque Distribution through a Two Stage Belt Drive
In a two-stage belt drive system with a maximum torque input of 110N, the torque distribution is influenced by the pulley sizes and belt widths. Although both stages have the same gear ratio, the torque consumption is not evenly split due to the difference in belt widths, with the first stage using a wider poly-v belt. The wider belt can handle more operating force, which is essential for the torque management in the system. If the pulley sizes differ, the larger pulley experiences less tensile force, affecting how torque is distributed across the stages. Understanding these dynamics is crucial for explaining design choices to customers and optimizing performance.
billinr
Hello All
I am trying to work through a belt drive design and I am confused with a simple concept.
I have a two stage system that has a max torque input of 110N. I want to treat this as "worst case", so I assume that all of the torque is used at the final output flywheel.
The first stage has the same ratio as the second stage, but the pulley sizes are different.
I have the belts designed, but my issue is that I need to explain to the customer why I am using a wider belt (poly-v) on the first stage than on the second. The second belt width is 80% of the first. This is what my calculation software tells me is correct.
The drive has been tested, so I know it works - I just do not know why it works.
Could someone explain to me:
When there are multiple stages in a drive, how does the relationship between the ratios affect how much of the torque is consumed in each system? With these two systems having the same ratio, do they each consume 1/2 the torque? (Obviously not, because of the belt width difference??) Is this due to the differences in the pulley sizes?
For a future reference, if the system ratios were different, how does that affect the calculation?
Thanks for any assistance.
Belt width would be decided by the operating force of the belt. If you have two pulleys subject to the same moment, one twice the radius of the other, then the belt on the larger pulley will only be subject to half the tensile force of the belt on the smaller pulley.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
