Simple harmonic oscillators and a pendulum clock.
The discussion centers on understanding how gravitational acceleration (g) affects the timekeeping of a pendulum clock at different altitudes. The user is struggling to incorporate the changing value of g into the simple harmonic oscillator (SHO) equation for the pendulum. It is noted that the period of a pendulum is influenced by its length and the value of g, which is crucial for solving the problem of the clock losing time at higher altitudes. Additionally, there is a suggestion that the problem may involve understanding proportional changes rather than re-deriving the pendulum formula from scratch. Overall, the focus is on clarifying the relationship between gravitational changes and pendulum behavior in timekeeping.
clayton26
Hey physics forums, this is my first post and frankly I'm having trouble conceptualizing this problem. I know harmonic oscillation is involved, as it is a pendulum. However, I know I have to incorporate g into the s.h.o. equation and I'm not quite sure how to do that. Any help would be greatly appreciated.
A pendulum clock which keeps correct time at a point where g=9.8 m/s^2 is found to lose 10 seconds per day at a higher altitude where the gravitational field now has a new value g(n). What is the numerical value of this g(n)?
This is from the force diagrams I've drawn.
Tcos(theta)-mg=ma(x)
Tsin(theta)=ma(y)
I'm lost. Please help!
Tsin(theta)=ma(y)
The period of a pendulum with small amplitude - like you find on a clock - is related to the length [which doesn't change] and g [which is changing]
I think this problem is more about proportional or percentage change than re-deriving the formula for a pendulum.
The other trick is to work out whether the clock is running fast or slow in the mountains, and what that says about the pendulum.
Are you expected to derive the period of a pendulum from first principles, or can you use the (well known) formula directly? It can be found in a few seconds with a web search.
