Motor sizing query for design project.
The discussion centers on motor sizing for an engineering cleaning application involving a cylindrical block that weighs 92kg and operates within a vacuum chamber. The user seeks to determine the appropriate motor power to achieve a minimum speed of 500 RPM, emphasizing the importance of calculating friction losses and acceleration requirements. They note that these calculations can be complex and may require experimental data. As a practical solution, oversizing the motor is suggested, as it could be more cost-effective than the labor involved in precise calculations. This approach balances performance needs with engineering efficiency.
ukmitch86
Hi there - this is my first post and I hope one of many to come!
My query is a relatively simple one; I'm working with an engineering cleaning application where fluid will be fed into a cylindrical block and spun out into a surrounding container.
The block is 3.5m long and ∅0.140m, weighing in at 92kg. It sits inside a vacuum chamber weighing 48.6kg, total 140.6kg.
I think a belt drive solution will be most practical from a design perspective, and I'm trying to size the motor to drive the load at a frequency of minimum 500RPM.
It's a long time since I've done this sort of calculation.
I would first and foremost look at the power requirement. How many watts of power do you need? For that you need:
  1. The friction losses at maximum speed. Usually, that can not be calculated, but only determined by experiment.
  2. The acceleration requirements. How much time is allowed to go from zero to full speed. That can be paired with the masses and moments of inertia of rotating pieces, and apply F=ma.
If those calculations prove difficult, the most common practical solution is to oversize the motor. The additional cost of a motor that may be 3-10 x bigger than your needs, may be cheaper that the cost of your engineering labor to calculate the minimum size.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
