Angular Momentum of an object with respect to a moving point
The discussion revolves around calculating the angular momentum of particle B with respect to particle A about a fixed point O. Two approaches are presented: the first involves calculating the angular momentum of both particles relative to O and then finding their vector difference, while the second approach considers the relative motion of B with respect to A. The first approach is shown to be flawed because it can lead to incorrect conclusions, as demonstrated by a counterexample where both particles have the same angular momentum about O. The correct method involves using the relative position and velocity of B with respect to A to accurately compute angular momentum. Ultimately, the key takeaway is that angular momentum cannot be treated like position vectors when determining relative motion.
Tanya Sharma
Two particles A and B having equal masses m are rotating around a fixed point O with constant angular speed ω .A is connected to point O with a string of length L/2 whereas B is connected to point A with string of length L/2 .Find the angular momentum of B with respect to A about O.
O-------L/2-------A-------L/2--------B
There can be two approaches
1.We find angular momentum of B w.r.t O ,say L1 = mω2L.Then we find angular momentum of A w.r.t O ,say L2 = (mω2L)/4.Since angular momentum is a vector , angular momentum of B w.r.t A should be vector difference of L1 and L2 =(3/4)(mω2L)
2.We find relative velocity of B w.r.t A =ωL/2 ,i.e we have considered particle A to be at rest .Then we find shortest distance between point A and line of motion of B which is L/2 .
Now,angular momentum of A w.r.t B =(mω2L)/4
I feel approach 1 is the correct way of calculating angular momentum of a point with respect to a moving point ,but the correct answer is the one given by approach 2.
Which is the right way ?
Hello.
To see that method 1 doesn’t work, consider the case where the equal masses A and B are at the ends and the axis O is in the middle: A----------O----------B. The system revolves about O. Then A and B would have the same angular momentum vector about O. So, if you tried to get the angular momentum of B relative to A by subtracting the angular momenta of A and B about O, you would get zero. But that can’t be correct as B is moving relative to A.
For a general situation, you can see more formally why it doesn’t work by noting that ##\vec{L}_{A/O} =m_A \vec{r}_{A/O} \times\vec{v}_{A/O}##. Similarly for particle B. If you subtract them, you can see that it's not possible in general to reduce it to ##\vec{L}_{B/A} =m_B \vec{r}_{B/A} \times\vec{v}_{B/A}##
The reason you can subtract two velocity vectors to get a relative velocity is because of the relation between the position vectors: ##\vec{r}_{B/A} = \vec{r}_{B/O} - \vec{r}_{A/O}## which holds at each instant of time. Taking the time derivative gives the relative velocity formula.
Hello TSny
Thank you very much for the explanation :smile:
So , I guess my misconception stemmed from the fact that I was treating Angular Momentum which is a vector in the same manner as we treat position vectors .ie \vec{L}_{A/B} =\vec{L}_{A/O}+\vec{L}_{B/O} ,which is not the correct way. Instead I should have dealt Angular Momentum of A w.r.t as \vec{L}_{B/A} =m_B \vec{r}_{B/A} \times\vec{v}_{B/A} .
Am I correct in assessing my mistake ?
Yes, I think that's right. There's no reason why angular momentum vectors would be related the same as position vectors.
TSny...thanks once again
