When is electric field zero and electric potential non zero
Electric potential is a scalar quantity, while electric field strength is a vector quantity. The incorrect statement in the discussion is that electric potential is zero whenever electric field strength is zero. An example provided illustrates that at the midpoint between two positive charges, the electric field can be zero while the electric potential remains non-zero. This is confirmed by the relationship that electric potential decreases with distance, allowing for a constant potential even when the electric field is absent. The reasoning presented is valid, highlighting the distinction between electric field and potential.
mrcotton
Which one of the following statements about electric field strength and electric potential is
incorrect?
A Electric potential is a scalar quantity.
B Electric field strength is a vector quantity.
C Electric potential is zero whenever the electric field strength is zero.
D The potential gradient is proportional to the electric field strength.
E=K Q/(R^2)
V=K Q/R
K=1/(4∏ε)
The answer is C
If for example you had two positive charges of 3 coulombs a distance 4m apart.
The electrostatic field at the midpoint would be zero. Effectively a positive charge at this point would be push by an equal force in both directions.
However the Electric potential V would be 2*(k*(3/4)
So you can have a zero E with a non zero V
Is this logic ok
Thanks for any help
Is this logic ok
Thanks for any help
The electrical potential goes as 1/r, but your reasoning is correct. You could also consider the electric potential and electric fields associated with spherical conductors: Provided the conductor is closed, the E field inside is 0 but the potential is a constant.
