Surface area proof (vector analysis)
randomcat
edit: vector* analysis; sorry for the typo
Given that A = ||ru||2, B = ru\bulletrv, C = ||rv||2
surface area of S is Area(S) = \int^{d}_{c}\int^{b}_{a} = sqrt (AC - B2) dudv
The Dirichlet energy can be thought of as a function as follows
E(S) = 1/2\int^{d}_{c}\int^{b}_{a} = (||ru||2+||rv||2) dudv
Show that Area(S) ≤ 1/2 E(S) and that equality holds if
||ru||2 = ||rv||2 and ru \bullet rv = 0
Given that ||ru||2 = ||rv||2 and A = ||ru||2 I know that
E(s) = 1/2\int^{d}_{c}\int^{b}_{a} = (2A) dudv
= \int^{d}_{c}\int^{b}_{a} = (A) dudv
Since A = C, and B = 0, then Area(S) = Area(S) = \int^{d}_{c}\int^{b}_{a} = sqrt (A2) dudv
which is just
\int^{d}_{c}\int^{b}_{a} = A dudv
So I showed that they're equal, but how do I justify that Area(S) is less than 1/2 E(S)?
Looks to me that it should not depend on the integration, i.e. If it is going to be true then it should be provable by comparing the integrands.
So investigate (||ru||2+||rv||2) 2
Hmm...I'm not sure where that leads me in the proof, could you please elaborate?
(Just noticed that in every one of your integrals the integral sign is separated from the integrand by an equals sign. I'm assumng that's a typo. If not, there's somethng in your notation I'm not familiar with. Also, you seem to have too many 1/2s floating around. Either there's a 1/2 in the definition of E(S) or there's a 1/2 in the inequality to be proved, not both.)
Compare the squares of the integrands, i.e. compare (||ru||2+||rv||2) 2/4 with AC-B2. Can you see that one is guaranteed at least as large as the other?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
