Electric model Car design calculations help.
To calculate the force (F) for the electric car design, it's essential to consider that maximum speed is achieved when engine force equals air resistance plus friction, which complicates direct calculations without those values. The user has specified a maximum speed of 2 meters per second and a mass of 1.45 kg but lacks information on air resistance and friction. Additionally, to determine torque at the wheel, knowing the wheel radius of 28 mm is necessary, but further details on force are required for accurate calculations. The discussion highlights the challenges in performing calculations without complete data. Accurate design calculations will ultimately depend on empirical testing or more detailed specifications.
arjg89
Hello,
I am needing help with some calculations for my project. I have to design an electric Car design and have to include some calculations. Given the maximum speed of the car is 2Meters per Second and the the mass of the car is 1.45kg:
Calculate F
And how do i calculate the torque at the wheel if I know the radius of the wheel which is 28mm.
Thanks.
arjg89.
welcome to pf!
hello arjg89! welcome to pf! :smile:
Calculate F
the maximum speed is reached when the maximum force (F) of the engine equals the air resistance plus the friction within the engine and the bearings (which increase with speed)
if you don't know the air resistance or the friction (and i don't see how you can know it), then you can't find F without actually building the car :wink:
I don't actually need to know the air resistance or the friction for my assignment.. This is all the information I have been given..
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
