How Do I Choose the Right Scale for Modeling Link Lengths?
  • Thread starter Thread starter mech-eng
    Links Scale
Choosing the right scale for modeling link lengths involves determining a convenient ratio based on the shortest link. A suggested approach is to set the smallest link length, 76.2 mm, as 1 unit, which would scale other links proportionally. The discussion also mentions using a scale of 1 cm for every 50 mm, but clarity on the purpose of the model is essential for accurate scaling. Understanding whether the goal is a drawing or a physical model can influence the scale selection. Ultimately, establishing a clear purpose will guide the choice of scale effectively.
mech-eng
hello all. here are link lengths Link 1=177.8, Link 2=228.6, Link 3=76.2, Link 4= 203.2 . I don't know how I can choose a convenient scale for these links.Do you have any idea? For example is it a good approch to choose 1 cm for 50 mm.to what centimeters can I roll the numbers. Link ratios to the shortest are such as 2.667 or 2.333.
Why don't choose your scale as the smallest link length? This way you'll have down scaled link lengths as 1 unit, 2.322, 3 and 2.667 units.
It's not clear what your purpose is. Are you making a drawing? Are you making a model?
I am trying to solve a problem on paper.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
