Making TiO2 dissolve in acid organic
To dissolve titanium dioxide (TiO2), it is essential to use specific solvents, as common acids like H2SO4, HCl, HNO3, citric acid, and ascorbic acid have proven ineffective. The most effective solvents for TiO2 dissolution are hydrofluoric acid and hot, concentrated sulfuric acid, though both are highly hazardous and require careful handling. The discussion highlights the challenges faced in dissolving TiO2 and emphasizes the need for caution when using strong acids.
Desy
Hi, everyone..
I do want to know, what are parameters that I have to know to dissolve TiO2,,?? I have tried many solvents like H2SO4, HCl, HNO3, citric acid, ascorbic acid, equi-molar citric/ascorbic acid,, but all was fail.
could you tell me,,??
Thank you.. :)
Chemistry news on Phys.org
See this article, p. 2:
ftp://ftp.fao.org/ag/agn/jecfa/cta_tio2.pdf
You can forget citric acid or ascorbic acid. TiO2 only slowly dissolves in hydrofluoric acid or hot, concentrated sulfuric acid, both of which are extremely dangerous to handle.
Why the interest?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
