How Do Electric Fields Differ Between Aluminum and Glass Plates?
The electric field generated by a charged aluminum plate is calculated using the formula E = σ/2ε0, where σ is the surface charge density. In contrast, the glass plate, being an insulator, does not allow for the same distribution of charge and requires a different approach. The electric field for the glass plate is E = σ/ε0, reflecting its inability to conduct electricity like aluminum. This distinction leads to a stronger electric field for the glass plate compared to the aluminum plate when both have the same charge. Understanding these differences is crucial for analyzing electric fields in various materials.
jesuslovesu
A very large flat aluminum plate of area A has a total charge Q over its surface. The same charge is placed over the upper surface of a glass plate. Compare the electric fields.
I know how to get the electric field of the aluminum plate.
\sigma = Q/A
2EA = \sigmaA/e0
E = \sigma/2e0
For the glass plate, I'm not so sure... Initially I would think E = \sigma/e0, but it isn't...
Realize that the aluminum plate is a conductor.
