Pump head and flow rate relation
Increasing flow rate in a pump system typically results in a decrease in head, as indicated by the pump characteristic curve. The relationship between RPM and flow rate is governed by the pump affinity laws, which explain how changes in speed affect performance. It is possible to adjust pump head by modifying system resistance rather than RPM, which can lead to increased flow. Specifically, reducing pressure resistance in the system can enhance flow rates while maintaining a constant RPM. Understanding these dynamics is crucial for optimizing pump performance.
eaaaazizo
i need some help becoase i become confused
according to pump characteristic curve if the flow rate increased the head will decreased
the question is how i can increase the flow rate and what is the relation of RPM with head and flow rate
russ_watters said:
Have a look at the pump affinity laws: http://www.engineeringtoolbox.com/affinity-laws-d_408.html
thank u for ur answer but this link is speake about changing rpms it is available to change the pump head by change pump capacity with constant RPM and how ?
By combining the first and second equations, you get an equation that tells you that by lowering the pressure resistance in the system, you'll get an increase in flow.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
