How Do You Solve These Physics Problems Involving Tension, Friction, and Motion?
  • Thread starter Thread starter bknice02
    Fun Tension
To solve the physics problems involving tension, friction, and motion, focus on analyzing the resultant forces acting on the objects. For the hammock scenario, apply the principles of tension and angles to determine the force in the ropes. In the case of the backpack on the table, use Hooke's Law (F = -kx) to find the force of friction when the spring is stretched. For the box on the conveyor belt, calculate the time it takes to stop sliding by considering the coefficient of kinetic friction and the initial speed. Providing your work will allow for more specific guidance on any issues encountered.
bknice02
1. A 52.0 kg person takes a nap in a (lightweight) backyard hammock. Both ropes supporting the hammock are at an angle of 14.9° above the horizontal. Find the tension in the ropes.
2. A backpack full of books weighing 52.0 N rests on a table in a physics laboratory classroom. A spring with a force constant of 155 N/m is attached to the backpack and pulled horizontally. (a) If the spring is pulled until it stretches 1.70 cm and the pack remains at rest, what is the force of friction exerted on the backpack by the table?
3. A box is placed on a conveyor belt that moves with a constant speed of 1.38 m/s. The coefficient of kinetic friction between the box and the belt is 0.920. (a) How long does it take before the box stops sliding relative to the belt? (in seconds) (b) How far has the box moved in this time? (in meters)
I don't expect to be given the answers, I just need to be pointed in the right direction
Look at the resultant Forces
F=-kx
not much else I can help you with without you showing what you've done. then we can point out any problems in what you're doing.
