A boy that jumps off a skate, v of the skate=?
  • Thread starter Thread starter frank1
A boy weighing 30kg jumps off a skateboard weighing 4.9kg, both initially moving at 2.2m/s. After the jump, the boy's velocity relative to the skateboard is 3m/s. The momentum conservation equation is applied to find the skateboard's velocity after the jump. The calculations confirm that the skateboard's velocity is approximately -0.3787m/s, indicating it moves in the opposite direction. The method used for solving the problem is validated as correct.
frank1
A boy of 30kg is riding a skateboard of 4.9kg and both are going on with a velocity of 2.2m/s. In a moment the boy jumps forward, pushing the skate to the other direction. Immediatelly after the jump, the horizontal velocity of the boy in relation to the skate is 3m/s. Whats the velocity of the skate in this moment?
What I've tried to do:
Momentum before=Momentum after
(mass of the system skate+boy)(initial velocity)=(mass of boy)(velocity of boy)+(mass of skate)(velocity of skate)
I think what I am probably missthinking is the velocity of the boy, because in the question, he says "velocity of the boy in relation to skate", so i suppose, it would be: (mass of the boy)(3 + velocity of the skate)?
It sounds wrong, i don't know why XD
Can somebody give me a light here?
Hi frank! Welcome to PF!
The question has given you the velocity of the boy relative to the skate. That means,
V_B - V_S = V_{BS} = 3
So yes, you got it right! :smile:
So can you check if I am doing it correctly?
look:
(34.9)x(2.2)=30(3+Vs)+4.9Vs
76.78=90+30Vs+4.9Vs
-13.22=34.9Vs
Vs=-0.3787m/s
EDIT: thanks for helping so quickly :)
look:
76.78=90+30Vs+4.9Vs
-13.22=34.9Vs
Vs=-0.3787m/s
Yep, your method looks correct! :approve:
