A conducting rod slides down between two frictionless vertical copper tracks
A conducting rod slides down frictionless copper tracks at a constant speed of 4.5 m/s in a 0.56-T magnetic field. The rod has a length of 1.2 m and maintains electrical contact with the tracks, with a negligible resistance. The change in gravitational potential energy over 0.20 seconds was initially calculated incorrectly, with attempts yielding values of 0.485727 J and 0.20483 J. The confusion arose from not accounting for the electromagnetic force due to induction, which affects the rod's motion. Understanding the role of electromagnetic induction is crucial for accurately determining the potential energy change.
cclement524
A conducting rod slides down between two frictionless vertical copper tracks at a constant speed of 4.5 m/s perpendicular to a 0.56-T magnetic field. The resistance of the rod and tracks is negligible. The rod maintains electrical contact with the tracks at all times and has a length of 1.2 m. A 0.82-Ω resistor is attached between the tops of the tracks. Find the change in the gravitational potential energy that occurs in a time of 0.20 s.
s = ut+ (1/2) gt^2
U = mgh
I found the mass of the rod to be 0.2528777 kg
Here's my attempt at the answer, but I went wrong somewhere (I'm positive the mass I found is correct):
From the kinematic relations
s = ut+ (1/2) gt^2
= 0 +(1/2)gt^2
= (0.5)(9.80 m/s2)(0.20 s)^2
= 0.196 m
The change in the gravitational potential energy is
U = mgh
=( 0.2528777 kg)(9.80 m/s2)(0.196 m)
= 0.485727 J
My second attempt:
When it comes to finding ∆h I assumed free-fall (used 'g') ... but the rod was falling at constant speed
so I tried ∆h = 0.9 m
=(0.2528777 kg)(0.9 m)
= 0.20483
Neither of these are correct, but I am confused as to where I went wrong.
there will be force due to electromagnetic induction. F = BIL
Got it-- thank you!
welcome.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
