How Do You Calculate the Tension and Elastic Properties of Suspended Wires?
  • Thread starter Thread starter BadlyAddicted
    Materials
The discussion focuses on calculating the tension and elastic properties of two suspended wires made of steel and copper. The tension in each wire is determined to be 39.4 N, based on the total weight supported by the uniform bar and the suspended mass. The extension of the steel wire is calculated to be approximately 0.00796 m. The Young's modulus for the copper wire is found to be 2.37 x 10^11 Pa. These calculations utilize fundamental equations of strain, stress, and Young's modulus to derive the necessary properties of the materials involved.
BadlyAddicted
Two wires each of 2.50m long, one of steel of diameter 1.0mm and the other of copper of diameter 0.56mm are suspended from two points in the same horizontal plane 200mm apart. The lower ends of the wires are fixed to the two ends of a uniform bar 200mm long and of weight 20.0N
A mass of 6.0kg is suspended from the center of the bar. The bar tilts at 0.8degrees to the horizontal. The young modulus of steel is greater than that of copper. Assume the wires remain vertical.
i) What is the tension in each wire?
ii) Calculate the extension of steel
iii) Determine the young modulus of the copper wire
v) Calculate the strain energy stored in the two wires.
The acceleration of free fall is 9.8ms^-2 and the Young modulus of steel is 2.0 * 10^11 Pa.
The equations to be used are probably these (from my knowledge):
strain = extension/length
stress = tension/area
young modulus = stress/strain = FL/Ae
i) [ 20 + (6 * 9.8) ] / 2= 39.4
If someone could work out ii and iii for me showing all the working i'd appreciate. i believe i can proceed from there
with the information given.ii) Extension of steel = [ ( 20 + (6 * 9.8) ) / 2 ] * 0.01m / (2.50m)= 0.00796miii) Young Modulus of Copper = FL/Ae = [ ( 20 + (6 * 9.8) ) / 2 ] * 0.01m / (0.56mm * 0.00796m) = 2.37 * 10^11 Pa
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
