A question on Newton's 3rd Law
  • Thread starter Thread starter DiamondGeezer
    Law
The discussion focuses on the application of Newton's 3rd Law and conservation of momentum in a system where a mass M ejects a smaller mass m, resulting in the larger mass (M-m) moving in the opposite direction. The initial velocity of the remaining mass is derived using the equation mu + (M-m)v = 0, leading to v0 = mu/(M-m). The motion of the remaining mass is described as simple harmonic motion (SHM), with energy conservation equations relating kinetic and spring potential energy. The equations of motion involve trigonometric functions, allowing for the calculation of position, velocity, and acceleration over time. The discussion emphasizes the relationship between initial kinetic energy and spring energy to determine the amplitude of oscillation.
DiamondGeezer
I don't have a diagram for this but I hope the description is vivid enough.
Imagine a mass M on a horizontal smooth surface (ie no friction). The mass M is between two bars equidistant from M and connected to the mass via two springs (if you imagine a square mass with springs attached to the corners which connect to the fixed bars). The springs are ideal springs of spring constant k and the mass M is sitting at the equilibrium position
At some time t=0 a small mass m is ejected from the larger mass M and embeds itself in putty in one of the fixed bars.
The mass (M-m) therefore will react to the ejection of m by moving in the opposite direction and will exhibit SHM about the equilibrium position.
I guess that if the mass m leaves the larger mass M at speed u, then the law of conservation of momentum would mean that the remain mass will recoil at velocity v such that
mu + (M-m)v=0
Is this correct?
What would be the equation of motion of the mass (M-m)?
At this very moment(t=0),the mass(M-m) will recoil at the speed v0=mu/(M-m).Then from now on,the remain mass can be regarded as a spring oscillator,whose initial speed is v0.
If you want to know the motion equation of the remain mass(Let's call it M').You need the knowledge of trigonometric functions.
For M',the energy conservation equation is:
0.5(M-m)v02=0.5×2k×A2(A:amplitude)---------(1)
while ω=(2k/m)0.5--------------(2)
and x=Asin(ωt)----------(3)
Now you can get an function x(t) by (1)-(3).I'm sorry that I cannot write the result here for it's a little complicated.
As you have got x=x(t),you can write down v=v(t) and even a=a(t) easily by derivation.
\xi=Asin(kx-wt) is the general eqn.
To get A equate initial K.Eof (M-m) to the spring energy when the K.E of (M-m) becomes zero. "w" is the angular frequency and "k" is the wave no of the wavw describing the motion of (M-m).Hope I helped...
