A SIMPLE integral, but I want a nice way to solve.
  • Thread starter Thread starter 1MileCrash
    Integral
1MileCrash
p(t) = cos(t) + (1)/(cos^2(t)
Find antiderivative.
Alright, I'm just starting calc 2. I thoroughly covered a lot of integration involving u substitution, and we have not started that in calc 2 yet. U substitution is so ingrained into my mind right now.
Wolfram gives sin(t) + tan(t) which I agree with by quickly going through differentiation, but what rules of integration would you apply? I'm guessing some algebra or trig identity?
That p(t) is exactly equal to cos(x) + sec2(x). This can be done simply with direct integration.
You can also solve it like this:
p(t) = cos(t) + \frac 1{cos^2(t)}
Substitute u=cos(t):
p(t)=u+u^{-2}\int p(t)= \int u+u^{-2}=...
That's a possible way if you wan't to use substitution. :smile:
That's a possible way if you want to use substitution. :smile:
If u=cos(t) , then du = -sin(t) dt . Furthermore, \displaystyle \sin(t) = \sqrt{1-\cos^2(t)} = \sqrt{1-u^2}\,.
Therefore, \displaystyle \int p(t)\,dt= -\int \left(u+u^{-2}\right)\sqrt{1-u^2}\,du\,.
So, that's probably not the way to go.
See Yuqing's post for a straight forward method.
Sorry but that's invalid specifically because that is a "substitution" but you ignored the "dx" and "du". If u= cos(t) then du= -sin(t)dt. To integrate \int (cos(t)+ 1/cos(t)) dt and letting u= cos(t) you would have \int (u+ 1/u^2)dx and substituting for dx will give you a very complex integral.
Here's a solution. However, it does require the circular reasoning that the derivative of tan is sec2. If you can ignore that though, it's legit:
\int sec^{2}x dx = \int \sec^{2}x \frac{\tan x}{\tan x} dx
Letting u = tanx, du = sec2x dx, we get:
\int \frac{u}{u} du = \int du = ...
But the "tan x/tan x" is irrelevant. All you are doing is saying d(tan(x)= sec^2(x)dx so \int sec^2(x)dx= \int d(tan x)= tan(x)+ C.
I had a student who would routinely carry out his substitutions this far. At first it caught me off guard. Then I caught on to what he was doing. He would pick u so that du/dx was equal to the whole integrand, so that he would get: \displaystyle \int\,\frac{du}{dx}\,dx=\int\,du=u+C\,.
From that time on, I would often refer to this as "Huang's method" , crediting that student.
Good point. I didn't realize this.
