Acceleration of a box pulled up a ramp with friction
The problem involves a 160kg box on a 35-degree inclined plane, with a rope and pulley system applying a tension of 1240 N. The scenario includes considerations of static friction with a coefficient of 0.45, and participants are tasked with determining whether the box will move up the ramp and its potential acceleration.
  • Exploratory, Assumption checking
  • Participants discuss the forces acting on the box, including tension, friction, and gravitational components. There is an exploration of whether the force of tension is sufficient to overcome the combined forces of friction and gravity acting down the ramp.
Some participants express confidence in the calculations presented, while others indicate a desire for further verification, particularly in relation to the next problem involving kinetic friction. There is no explicit consensus, but the discussion appears to be productive with participants affirming the original poster's approach.
Participants note that the subsequent problem will involve different parameters, specifically a coefficient of kinetic friction, which may influence their understanding of the current problem's dynamics.
M4573R
A 160kg box is on a plane with an incline of 35 degrees. A rope is attached to the box and a pulley at the top of the ramp and has a tension of 1240 N. The static coefficient of friction is 0.45. Will the box move up the ramp? If so, what is its acceleration?
Total force on box = m*a
Is Force of tension >= Force of friction + Force of gravity down ramp(?)
Force of static friction = umg*cos(theta) = 0.45*160.0*9.81*cos(35) = 579 N
Force of gravity down ramp = mg*sin(theta) = 160.0*9.81*sin(35) = 900 N
Force Total = m * a
1240 N >= 579 N - 900 N
1240 N >= 1479 N -> No it won't slide up the ramp.
I hope this is correct, I'm not sure if using the force acting down the ramp is correct or not.
Well done, it looks good to me.
The next problem implies the box reaches the top of the ramp and we are given a coefficient of kinetic friction, So I want to make extra sure.
I just read over it again and it looks fine.
