Acceleration Problem due to Rotational Inertia [Exam in 9hrs]
To solve the acceleration problem involving two blocks and a pulley, it's essential to apply Newton's Second Law to both blocks and the pulley. The net torque on the pulley can be expressed as Στ = Iα, and the relationship between linear and angular acceleration must be utilized with a = rα. The initial calculation of acceleration using a = F/m is incorrect because it doesn't account for the rotational inertia of the pulley. The correct approach will yield an acceleration that matches one of the provided choices, which are 3.5, 3.9, 2.5, less than 2.5, or cannot be determined. Properly setting up the equations will lead to the accurate solution needed for the exam.
maxxed
[URGENT] Acceleration Problem due to Rotational Inertia [Exam in 9hrs!]
yes i know i might be late but i hope somebody can help me out with this problem because i can't figure it out. Exact word for word:
A block of mass m2= 12kg hangs from a rope. The rope wraps around a pulley and then attaches to a second block of mass m1=8kg, which sits on a frictionless table. The radius of the pulley is .10m and its rotational inertia is I=.040 kg-m2. What is the acceleration of the blocks when they are released.
here is how it looks:
http://spiff.rit.edu/classes/phys311/workshops/w5b/level_atwood/cart_and_weight.gif
a modified atwood machine.
You essentially need to draw 3 free body diagrams. Use Newton's Second Law to set up the equations for the two blocks, and Newton's Second Law for rotational motion, \Sigma \tau = I \alpha to set up an equation for the net torque on the massive pulley. Also note, you'll want to use the rolling constraint a = r \alpha to get the angular acceleration in terms of "a." Does this help?
sort of i was using
a=F/m
F=m2g->12*9.80=118
m=12kg + 8kg
a=5.9
but its not one of the choices which are:
a. 3.5
b. 3.9
c. 2.5
d. less than 2.5
e. cannot be determined
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
