Air Navigation and Course Correction. Semester exam in 45 minutes.
A pilot needs to fly 2875 km at an angle of 18 degrees east of north, aiming to complete the trip in 3 hours and 20 minutes. Due to a 130 km/hr wind from the south, the pilot must adjust his heading to maintain the correct course. To solve the problem, the ground speed and air speed must be calculated using the cosine law and sine law, considering the wind's effect on the plane's trajectory. The initial step involves determining how far the wind will push the plane during the flight time, which will inform the necessary adjustments to the plane's velocity. Understanding the components of distance affected by the wind is crucial for accurate navigation.
pablot93
A pilot wishes to fly 2875 km to an airport 18 degrees east of north from his departure point(for the sake of the problem and simplicity, use the origin). He wants to make the trip in 3 hours and 20 minutes. The pilot finds that he actually has to make a change in his air heading to compensate for a 130 km/hr wind coming from due south. What should be his...
A)Ground Speed
B)Air Speed
C)Magnetic Compass heading
Cosine Law
c^2 = a^2 + b^2 - 2ab cosC
I know you make a parallelogram, with his ground speed and the wind speed, and then use the cosine law. From there, use the sine law. I just need someone to walk me through it please.
I have my physics exam in an hour and I'm still kind of iffy on these types of problem from the beginning of the semester.
A good place to start would be to see how much of the distance the wind speed would propel the plane in 3 and 1/3 hours.
Whatever is left is what the plane's velocity must compensate for, but remember that the wind is only going north which means you're going to need to break the distance into components.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
