How Fast Does Light Strength Change with Angle in a Searchlight Problem?
  • Thread starter Thread starter zaboda42
    Genius Welcome
zaboda42
Simple yet challenging calc problem - please help!
http://img252.imageshack.us/i/en8t.jpg/
a searchlight is located at point A 40 feet from a wall. The searchlight revolves counterclockwise at a rate of π/30 radians per second. At any point B on the
wall, the strength of the light L, is inversely proportional to the square of the distance d from A; that is, at any point on the wall L = k/d^2 . At the closest point P, L = 10,000 lumens.
a) Find the constant of proportionality k.
b) Express L as a function of θ , the angle formed by AP and AB.
c) How fast (in lumens/second) is the strength of the light changing when θ =π/4? Is it
increasing or decreasing? Justify your answer.
d) Find the value of θ between θ =0 and θ =π/2 after which L<1000 lumens.
I was only able to do part a) the other parts are rather confusing. If anyone could help that would be greatly appreciated.
My Attempt:
a) (40)^2 + (10,000)^2 = d^2
d = 10,000
L = k/d^2
10,000 = k/(10,000)^2
k = 1E12
b)
L = [.5(40 x 10,000)] x sin(theta)
L = 200,000 x sin(theta)
I'm sorry, I'm really confused and just need guidance to know if I'm doing this problem right, or if I'm completely wrong.
d)
999.999 =< 200,000 x sin(theta)
theta =< 0.005
I have a feeling I'm doing this terribly wrong =/
For A, you are given three unknowns (one of which is a constant) and the values for the two variables (what is the distance between point A and point P?). I'm sure that you can figure A out from there.
For B, what's the relationship between d and theta?
For C, think instantaneous rate of change.
For D, how what would you do if you were asked to find of x for y = 2x so that every value of x after that produced a y value that's greater than 10?
My answers are below in a spoiler so that you can check yours.
a) L(d) = k/d2
L(40) = 10000
10000 = k/402
16000000 (1.6 x 107) = k
b) cos(θ) = A/H = 40/d
d = 40/cos(θ)
L(θ) = k/(40/cos(θ))2 = 10000cos2(θ)
c) L(θ) = 10000cos2(θ)
dL/dθ = 10000•2•cos(θ)•-sin(θ) = -20000cos(θ)sin(θ)
when θ = π/4 --> dL/dθ = -20000cos(π/4)sin(π/4) = -10000
Since the derivative is negative, L is decreasing when θ = π/4
d) L(θ) = 1000
1000 = 10000cos2(θ)
1/10 = cos2(θ)
1/\sqrt{10} = cos(θ)
cos-1(1/\sqrt{10}) = θ
which is about .398π
Thanks so much ƒ(x), i personally loved your "hints" in the beginning because they really helped me look at the problems differently rather than me just getting an answer.
Thanks again.
Welcome
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
