Analysis of Functions I: increase, decrease, and concavity
josh_123
Hello I need help with these problems. The direction said
a. find the intervals on which f is increasing, b. the intervals on which f is decreasing, c. the open intervals on which f is concave up, d. the open intervals on which f is concave down and e. the x-cordincates of all inflection points
1. f(x)=x^4-8x^2+16
I find a,b c and d for this function. However I have trouble finding the inflection points for this function. When you find the inflection point you suppose to set up the second derivative of the function to equal 0 but I have no idea how to solve it afterward. Is there an inflection point for this equation?
f"(x)=12x^2-16
2. f(x)=x/(x^2+2)
so f'(x)=-x2+2/(x2+2)2
to find a,b I have to set this equal to 0 and solve it. How do I solve it? and what would be the second derivative and how do I solve it by setting it up to equal to 0 to know if it's concave up or down?
3. f(x)=x2lnx
The first derivative is 2xlnx+x. How do I solve it or know what is a, b is?and the second derivative is 2lnx+3. How do I use the second derivative to solve for c,d and e?
Please help! Thank you!
josh_123 said:
1. f(x)=x^4-8x^2+16
f"(x)=12x^2-16
So you need to solve the equation 12x^2-16 = 0. What is your problem?
josh_123 said:
2. f(x)=x/(x^2+2)
Use parentheses. The formula is wrong without them.
You will have a fraction. It can be zero if the nominator is zero.
josh_123 said:
3. f(x)=x2lnx
To find x where the derivative is zero, factor out x.
ehild
1. f(x)=x^4-8x^2+16
f"(x)=12x^2-16
What? You don't know how to solve 12x^2- 16= 0? Add 16 to both sides, divide both sides by 12, then take the square root of both sides.
2. f(x)=x/(x^2+2)
you are taking Calculus and do not know how to solve equations like this? Multiply both sides of the equation by that denominator to get 2- x^2= 0
Differentiate it, using the quotient rule again.
3. f(x)=x2lnx
Oh, c'mon! 2xln(x)+ x= x(2ln(x)+ 1)= 0. One thing you surely learned long ago is that a product is equal to 0 only if one or more of the factors is 0. So here, either x= 0 or 2ln(x)+ 1= 0: x= 0 or ln(x)= -1/2.
2ln(x)+ 3= 0 leads to ln(x)=-3/2. Again, you should have learned in algebra or precalculus that if ln(x)= a then x= e^a. Once you know where it zero, you can determine the intervals in which the second derivative is positive or negative.
Actually I finished this before checking back haha. Please delete this post
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
