Angles Formed by Particles' Positional Vectors
The discussion centers on determining the angle formed by the positional vectors of two particles, A and B, with given circular movements. Particle A has a radius R and an angular velocity of 2w, while particle B has a radius of 2R and an angular velocity of w. The angle between the positional vectors is influenced by the variable n, with potential angles being 0, 3π/2, π/2, or π. The consensus is that the angle is dependent on the value of n, with specific examples indicating that for n=1, the angle would be 3π/2.
  • Understanding of angular velocity and its implications in circular motion
  • Knowledge of trigonometric functions and their application in angle measurement
  • Familiarity with vector representation in physics
  • Basic principles of rotational dynamics
  • Explore the concept of angular displacement in circular motion
  • Learn about vector addition and subtraction in physics
  • Study the relationship between angular velocity and linear velocity
  • Investigate the effects of varying parameters in circular motion problems
Students studying physics, particularly those focusing on rotational dynamics and vector analysis, as well as educators seeking to clarify concepts related to angular motion and positional vectors.
davidpac
a particle A has a circular movement with radius R and angular velocity of 2w, a particle B has a radius of 2R and an angular velocity of w, both velocities remain constant. particle B rotates clockwise and particle A rotates anticlockwise for an interval of t = n/(2w)
what angle is formed by the positional vectors of these two particles?
the options are: 0, 3pi/2, pi/2, pi.
note: the vector of these two particle's movement have the same origin, their movement make two circles, which have the same origin. particle B's circle has double the radius of particle A.
They don't say absolutely anything about the value of n.
from a sketch I've made, I say the angle is pi/2. but again, it all depends on the value of n.
any ideas?
Some information is missing since the angle between the positional vectors will always be changing. It seems that the radius of each circle doesn't matter in terms of the angle between the position vectors.
EDIT: You're right, the answer is in terms of n, but none of the options have n in them.
w * t for particle A = -n radians
w * t for particle B = n/2 radians.
I have written absolutely everything that they gave me, I'm also finding it impossible to solve this problem.
Why would your teacher give you R?
if for example n = 1, the angle would be 3pi/2. do you agree?
I guess it depends on how you define negative and positive, but yes I agree.
It would be 3pi/2 if you measured clockwise from A to B.
  • · Replies 32 ·
