What is the Angular Deceleration of a Bicycle Wheel?
The discussion revolves around calculating the angular deceleration of a bicycle wheel based on the heights reached by water drops that detach from the tire. The user has converted the heights from centimeters to meters and calculated initial velocities using the maximum height formula. They also determined the time for one complete cycle for two different velocities. However, they express confusion about how to proceed with finding angular deceleration and seek guidance on converting tangential quantities to angular quantities. The conversation emphasizes the need for a kinematic formula that directly provides acceleration.
cdubsean
A bicycle is turned upside down while its
owner repairs a flat tire. A friend spins the
other wheel of radius 0.4 m and observes that
drops of water fly off tangentially. She mea-
sures the height reached by drops moving ver-
tically. A drop that breaks loose from the tire
on one turn rises 36.3 cm above the tangent
point. A drop that breaks loose on the next
turn rises 31.6 cm above the tangent point
(the angular speed of the wheel is decreas-
ing).
Find the angular deceleration of the wheel.
The acceleration of gravity is 9.8 m/s2 . As-
sume the angular deceleration is constant.
Answer in units of rad/s2.
Max height = (Vi^2)/2g
2pi(r)
Angular Velocity
Given what I know I converted units
36.3 cm to .363m
31.6 cm to .316m
Then used max height formula to determine the Vi
Vi1 = 2.6674 m/s
Vi2 = 2.4887 m/s
and with this I can find the time buy using the circumference and the velocities to determine the times.
T1= .9422s for one complete cycle
T2= 1.0099s for one complete cycle
And with this I need to use angular acceleration formula to get this, but here is where I am lost and fell like I am going in wrong direction. Can I get some guidance into what I should do next. I know that I might have to use this to find tangent line which between these two to find acceleration...in this cause deceleration. But I am lost.
Instead of this, which assumes constant speed over the course of each cycle, trying using a different kinematic formula that gives you the acceleration directly.
How do you convert tangential quantities (distance, speed, acceleration) to angular quantites?
