BraedenP
- 96
Two gerbils run in place with a linear speed of 0.55m/s on an exercise wheel that is shaped like a hoop. Find the angular momentum of the system if each gerbil has a mass of 0.22kg and the exercise wheel has a radius of 6.5cm and a mass of 5.0g.
[tex]L=rmv\sin(\theta)[/tex]
Basically, I just plugged in values for the variables in the above equation, except for the mass. I know that, since the gerbils aren't moving anywhere or going around the circumference of the wheel, they're not contributing to the angular momentum of the system.
However, I assume that they are adding mass to the system, so that should be taken into consideration when finding the answer. Thus, I calculated as follows:
[tex]L=0.065m \cdot (2 \cdot 0.22kg + 0.005kg) \cdot 0.55m/s \cdot sin(90)[/tex]
[tex]L=0.0159 = 1.6 \cdot 10^{-2} kg \cdot m^2/s[/tex]
Is that the proper way to do it? I just want to make sure that the mass of the gerbils should be included despite them being in the air part of the time as they run.
Thanks!
