Answer: Intensity Outside a 43.5 dB Quieter Room
  • Thread starter Thread starter chattkis3
    Intensity Levels
A recording engineer is trying to calculate the sound intensity outside a soundproofed room that is 43.5 dB quieter than the inside, where the intensity is 1.00 x 10^-10 W/m². The correct formula to use is the intensity level equation, which relates intensity in dB to intensity in W/m². After applying the formula, the intensity outside the room is calculated to be 2.24 x 10³ W/m². The engineer is advised to double-check their calculations to identify any mistakes. Understanding the distinction between intensity level in dB and intensity in W/m² is crucial for accurate results.
chattkis3
A recording engineer works in a soundproofed room that is 43.5 dB quieter than the outside. If the sound intensity in the room is 1.00 10-10 W/m2, what is the intensity outside?
Here is how I THINK I should be solving this problem.
Intensity level = 10dB * log ( I / Io)
Intensity level = 43.5
Io = 1x10^-10
SO
I = 10 ^ { (43.5 + logIo)/10 }
The computer is telling me I am wrong, can anyone help please? Thanks a lot!
I = (1e-10)10^(43.5/10)
Your approach is correct, but you may have made a mistake in your calculations. To double check, let's plug in the given values into the formula:
I = 10 ^ { (43.5 + log(1x10^-10))/10 }
= 10 ^ { (43.5 + (-10))/10 }
= 10 ^ { 33.5/10 }
= 10 ^ { 3.35 }
= 2.24 x 10^3 W/m^2
So, the intensity outside the room is 2.24 x 10^3 W/m^2. You may have made a mistake in your calculations, so double check your work to see where the error occurred. Keep in mind that the intensity level is measured in dB, but the intensity itself is measured in W/m^2. Hope this helps!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
