Application of integrals to find moment Inertia
Kumaken
I need to make a project that integrates physics with math, involving the use of integrals to find moment inertia of areas. The theory could be read here :http://www.intmath.com/applications-integration/6-moments-inertia.php
I need to make an object that applies the theory above. Can anybody recommend me what should I make?
*note : I have a few idea in mind like making small windmill or fan blades that rotate, but are they appropriate? Cause I think the theory only applies to 2D objects...
*another note : If it's too much hassle, what project do you think is simple that involves the application of integrals in physics? Thank you very much in advance.
For anything that is symmetric above with below a plane will be like you concentrated all the mass that has coordinates x, y into the xy plane, maybe that extends your possibilities.
Likes Kumaken
I'm sorry but I kinda do not understand... can you please elaborate? Sorry for the trouble.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
