At home engineering fun. disc and rod drum driver
The discussion revolves around driving a drum head using a rod that moves in response to changes in a disc's radius. Participants suggest two primary approaches: for smooth cyclical motion, a round disk with a peg can be used, while for a gradual change, a teardrop-shaped cam is recommended. Additionally, spring loading the system and using a reverse disk is proposed as a simpler solution. The consensus leans towards the teardrop or kidney-shaped disc for achieving the desired motion. Overall, the focus is on optimizing the rod's movement to effectively raise and lower the drum head.
JasonLA
I am driving a drum head with a rod. The rod goes up and down as the radius of a disc changes length (please see attached PDF). There is a gradual raise of the drum head, and then an abrupt drop. But there is a kink that the rod needs to overcome.
Any suggestions on how to achieve this motion?
thanks
Jason
Are you attempting to get that gradual change in the linear motion or do you want a straight cyclical motion? If just a cyclical motion is desired, use a round disk with a peg at some radius from the center. Attach the rod end to the pin. That will give you a smooth cyclical motion.
If you want that gradual change, how about making the cam a tear drop shape with a generous radius at both ends?
There are more complex solutions I can give you, but the simplest thing is to spring load it down and lift it with a reverse disk.
I also think the tear/kidney shaped disc is the way to go.
thanks for all of your suggestions.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
