Attribution of Reference Frame: A Dilettante's Question
In summary, different parts of an object may move with different speeds relative to a given reference frame, and there is no rule that requires all clocks on an object to tick at the same rate.
SteveF
I can't find an answer on my dilettante question about how we attribute reference frame to complex objects, where different parts move with different velocity or where different parts experience different influence of gravitation.
For example, we can take a human's body. If we take the full body as a reference frame, we can talk about time dilation compared to some other object external to this body. But at the same time we can take the head as a reference frame and "compare" it to feet. Also we can take neurons from the top of the brain and compare to neurons from the middle of the brain etc. Does this mean that there is no treshold for "framing"?
I think, first you need to learn what a reference frame is.
Likes Orodruin
A frame is a choice of a direction in spacetime to call "time" and choice of how to zero spatially separated clocks. You don't "attribute" a reference frame to any object.
It's certainly true that different parts of an object may have different speeds relative to a given reference frame. In that case, clocks at the different parts of an object may well tick at different rates (in fact, we can detect gravitational time dilation over distances small enough to know that a clock at your head height ticks at a different rate from one by your feet). The effect is too small for you to notice; in any circumstance where you could notice it you would have bigger problems.
There is no rule that requires all clocks on an object to tick at the same rate (which I think is the assumption underlying your questions).
Likes SteveF
To expand a bit on #2: A reference frame is an assignation of spacetime coordinates to uniquely identify events. In its essence, it has nothing to do with any object. It is just a computational aid.
You don't attribute reference frames to objects.
An object can be at rest in a reference frame, in which case we may refer to the reference frame as the rest frame of that object. But if different parts of an object are moving relative to each other, the different parts do not share the same rest frame.
Likes Nugatory
You will often hear people saying things like “the reference frame of <something>” or “<something> is in this frame”. Strictly speaking these are incorrect, but we say them anyway because it’s awkward to keep saying “the reference frame in which <something> is at rest”.
The “<something> is in this frame” wording is especially misleading because it suggests that things may be “in” some frames but not others. In fact everything is always in all frames; they’re just not at rest in some of them.
Likes SteveF
1. What is attribution of reference frame?
Attribution of reference frame is the process of identifying and assigning a specific coordinate system or frame of reference to a set of data or observations. This allows for accurate measurement and comparison of data within a specific context.
2. Why is attribution of reference frame important in scientific research?
Attribution of reference frame is important because it allows for the interpretation and analysis of data within a consistent and standardized framework. This helps to ensure that results are accurate and can be replicated by other researchers.
3. How is attribution of reference frame determined?
Attribution of reference frame is determined by identifying a set of fixed points or landmarks that serve as the basis for the coordinate system. These points can be physical objects or abstract concepts, and their location and orientation are used to define the reference frame.
4. What are some common types of reference frames used in scientific research?
Some common types of reference frames used in scientific research include Cartesian coordinates, polar coordinates, and geographic coordinates. Other specialized frames may also be used, depending on the specific field of study.
5. How does attribution of reference frame impact the interpretation of data?
The attribution of reference frame can greatly impact the interpretation of data by providing a consistent and standardized context for analysis. It allows for the identification of patterns and relationships within the data that may not be apparent without a defined reference frame.
