Beer Mug 2D Problem: Vel & Dir Calculation
  • Thread starter Thread starter GlobalDuty
    2d Beer
The discussion revolves around calculating the velocity and direction of a beer mug sliding off a counter. For part A, the user initially miscalculated the time it took for the mug to hit the floor, leading to an incorrect velocity of 1.4 m/s. After receiving feedback about the calculation error, the user successfully found the correct answer. The conversation also touches on the desire for quicker methods to solve similar physics problems. Overall, the focus is on understanding the motion of the beer mug in a two-dimensional context.
GlobalDuty
In a local bar, a customer slides an empty beer mug down the counter for a refill. The bartender is momentarily distracted and does not see the mug, which slides off the counter and strikes the floor 0.40 m from the base of the counter. The height of the counter is 0.730 m.
(a) With what velocity did the mug leave the counter?
(b) What was the direction of the mug's velocity just before it hit the floor?
For part A: I calculated the time it took for the beer mug to hit to floor vertically. Vyf-Vyi/g = t
for time i got .287 and so i did displacement/time= velocity which is:
.40/.287 to get 1.4 which is wrong.
How did you get Vyf?
i did Vyf^2 = Vyi^2 +2a(yf-yi)
that is squaring the initial velocity of Y which is zero and adding 2(accelaration)(0-.730)
In that case, you just made a calculation error. Try calculating again; t isn't 0.287 s.
thank you, i got the right answer. but isn't there a quicker way to do these types of problems?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
9K
