Find the Tension in Accelerating System: Understanding Kinetic Energy Storage
In summary: This makes sense.3) The PE assiociated with the block B is reduced as block B falls and all of the PE loss is transferred to block A as KE.This is the answer you were looking for. The PE of block B is reduced as it falls, and the KE of block A is increased as a result.4) The PE assiociated with the block B is reduced as block B falls,but only part of this loss of PE is transferred to block A as KE.This is also the answer you were looking for. Block B loses some of its PE, but only a part of that is transferred to block A as KE.
Bama
Find the tension ( stretching force) on the string whie system is accelerating. I know that the pull on block "A" for acceleration is gm2 / m1 + m2. so what is the source of the kinetic energy store in block "A". :confused:
  • block A & B.doc
Apply Newton's 2nd law to both blocks. That will allow you to solve for the acceleration and the tension in the string. (I assume that pulley in the middle is frictionless and massless; if not, analyze it as well.)
The "source" of the KE of both blocks is the gravitational PE that is transformed into KE as the block falls.
To see if I under KE correct, let me give you an example of what i understand. We will use a television for example. Normally when you turn your television off, the power or energy is not there until you turn it on again, however if you have a standby option, would that stand by power be consider KE?
? No, that has nothing to do with kinetic energy. Kinetic energy is the energy in a moving body: (1/2)mv2.
So in other words, KE is like jump starting the energy in a moving body once it has been jump started, it is only energy until something cause it to stop abruptly of which PE is loss affect and and later transform back to KE. So the answer to my question in as far as the source of the KE in block A, should be
" As block "A" moves to the right, it losses PE that transfers to kinetic energy."
See attachment
As block A moves to the right and block B drops down, the system loses gravitational potential energy (since B is lowering) and gains kinetic energy.
Here is what confusing me. There are choices that states, PE is loss as B is lower, however it is worded in such a way as all the PE loss is transferred to A as Kinetic Energy or only parts of the loss of PE is tranferred to block A as Kinetic energy. As I understand your comments is the Kinetic Energy gain in B?
I'm not sure what you are saying. As B lowers, the loss of PE is transformed into a gain of the KE of the system (since they are tied together, B cannot speed up without A also speeding up--unless the string breaks). If the blocks weren't tied together, things would be different.
Doc, here is what I have. This problem seems simple but nerving as well. Here is the question and choices I am given. What you say makes a lot of sense however the choices I have are hard for me to understand. Question: What is the source of the kinetic energy stored in block A? Now I know it isn't number one but the others are a bit confusing for me. It seems as if it's a play on words but if it isn't, what key element should I have notice?
1) In falling, block B loss kinetic energy that transfers to block A.
2) As it moves to the right, block A loses potential energy that transfers to kinetic energy.
The key thing to understand is that this is a conservation of energy problem. Whatever PE the system loses will equal the KE that the system gains. Also realize that the system has two parts: block A and block B. Even though only one block actually falls, both blocks share the KE since they are attached.
Let's analyze each answer:
The blocks gain KE, so this one doesn't make sense.
Block A moves horizontally so its PE doesn't change, so this one doesn't make sense.
OK, partly right: The PE of block B is reduced since B is the block that falls. But if all of the PE loss went into the KE of block A, then block B wouldn't move! So this answer can't be right. (The blocks share the KE.)
That's the only one that makes sense.
Let me know if any of this is still confusing.
So with number 2 moving to the right should have never been consider because there isn't no left or right only horizontal and vertical. Do I feel like a fool on this one. No further explanation is needed but if you were me, where would you start over at? In order for me to eliminate or understand what I am being ask, I need to do what?
In your diagram, block A moving to the right is moving horizontally. So left-right is just another way of saying horizontal. What's wrong with answer 2 is that it states "block A loses potential energy": that's not true. If something only moves horizontally, its gravitational PE does not change.
1. What is kinetic energy storage?
Kinetic energy storage is the process of storing energy in a system by converting it into kinetic energy, which is the energy of motion. This can be achieved by accelerating a mass and then using the resulting kinetic energy to power a device or perform work.
2. How does kinetic energy storage work?
Kinetic energy storage works by using a motor or other device to accelerate a mass, such as a flywheel or spinning disc. As the mass accelerates, it gains kinetic energy, which can then be used to power a device or perform work. To store the energy, the mass must be able to maintain its speed without significant loss of energy.
3. What is the role of tension in an accelerating system?
Tension is a force that is exerted on an object when it is pulled or stretched. In an accelerating system, tension plays a crucial role in maintaining the motion of the mass and storing the kinetic energy. The tension force is responsible for keeping the mass in its circular path and preventing it from flying off in a straight line.
4. How do you calculate the tension in an accelerating system?
The tension in an accelerating system can be calculated using the formula T = m*a, where T is the tension force, m is the mass of the object, and a is the acceleration. This formula is based on Newton's second law, which states that the force exerted on an object is equal to its mass multiplied by its acceleration.
5. What are some practical applications of kinetic energy storage?
Kinetic energy storage has many practical applications, including in electric vehicles, flywheel energy storage systems, and regenerative braking systems. It is also used in large-scale energy storage systems for renewable energy sources, such as wind and solar power. Additionally, kinetic energy storage can be used in tools and devices that require a burst of energy, such as power tools or emergency backup systems.
