Understanding the Relationship Between Glancing Angle & Deviation Angle
The discussion focuses on the relationship between glancing angle and deviation angle in X-ray diffraction. The original poster assumes the glancing angle is zero when the atomic plane is parallel to the X-ray direction, but the solution indicates a glancing angle of 25.25 degrees. Participants are asked to clarify the relationship between the glancing angle, which is the angle between the incident X-ray and the atomic plane, and the deviation angle, which measures the angle between the original and reflected X-ray directions. A request is made for a clearer diagram to illustrate these concepts. Understanding this relationship is crucial for accurately interpreting X-ray diffraction results.
gxc9800
in the first photo , the direction of x-ray and the atomic plane are shown.
whereas for the 2nd photo , the
the direction of x-ray and the atomic plane are not shown... so i would assume the glancing angle = 0 . beacuse the atomic plane is parallel to the x-ray ...but in the solution , the glancing angle is 25.25
can someone please draw me a better diagram to show the relationship between the glancing angle( angle betww and deviation angle( deviation of X-ray from the original direction) ...
The deviation angle is the angle between the original ray and the reflected ray. Look at the first photo: how are the deviation angle and the glancing angle related?
The second photo shows the deviation angle. From the relation above, what is the glancing angle? Where is the atomic plane?
ehild
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
