Bug on spinning disk -- What distance does the bug fly off?
A bug crawls outward on a spinning disc at 210 RPM, with a static friction coefficient of 1.1. The goal is to determine how far the bug can move from the center before slipping occurs. The correct formula for centripetal force is Fc = m v²/r, not the incorrect expressions previously used. After correcting the calculations, a distance of approximately 0.022 meters is determined as the point where the bug slips. Accurate application of the equations is crucial for solving this problem.
reanamate
A bug crawls outward from the center of a compact disc spinning at 210 revolutions per minute. The coefficient of static friction between the bug's sticky feet and the disc surface is 1.1.
(static friction)(Gravity) = (centripetal force)
This may be wrong but I tried setting (Centripetal Force)= (Radius)(2(pi)(rps))^2
I have been getting .02 m but the website I'm using is saying that it's wrong.
I forgot to add that I am trying to find How far the bug gets from the center before slipping?
You have the wrong expression for the centripetal force. The correct expression is Fc = m v2/r. What you have is Fc = v2.
No, @reanamate has rω2. Changing "centripetal force" to "centripetal acceleration" everywhere fixes all the issues.
I get the same answer - well, 0.022m to be a little more precise. Maybe that's the problem.
That worked I just need .022 thanks for the help.
Having misread the parentheses, I stand corrected.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
