Bullet Lodges In Baseball (vertical)
A bullet weighing 0.028 kg is fired vertically into a 0.15 kg baseball, resulting in a combined speed of 29.1 m/s immediately after the collision. The baseball and bullet rise to a height of 37 m, prompting a calculation for the average force of air resistance during ascent. Attempts to calculate this force using kinetic and potential energy equations have led to confusion, with results around 0.293 N being questioned. The discussion highlights the need to account for additional forces acting against the upward motion, suggesting that the correct answer may indeed be negative, indicating resistance. The complexities of the problem emphasize the challenges of applying conservation of momentum and energy principles in real-world scenarios.
Schoomy
A 0.028 kg bullet is fired vertically at 185 m/s into a 0.15 kg baseball that is initially at rest. The bullet lodges in the baseball and, after the collision, the baseball/ bullet rise to a height of 37 m.
(a) What was the speed of the baseball/bullet right after the collision?
(b) What was the average force of air resistance while the baseball/bullet was rising? (Consider the positive direction to be upwards.)
conservation of momentum.
m1v1=m2v2 yeilding v2 (velocity of ball/bullet combo) of 29.1 m/s.
This was correct.
However, I can't figure out b.
I tried using Force of Air Resistance = KE - PE, but that doesn't work.
I also tried using Force Air Resitance =KE/h - m(total)-g
That didn't work either (found it on yahoo answers).
What am I missing here?
This was correct.
I think you need to consider that KE = PE_final + W_air
Where
W_air = AvgForce_air * distance.
Yes, but I still don't get the right answer even then:
Thus, W_air = KE - PE
specifically:
Wair = ((.5)(.178)(29.1^2)) - ((.178)(9.8)(37)) = 75.366-64.543 = 10.823
Then,
becomes:
AvgForce_air = w_air / distance
AvgForce_air = 10.823 / 37 = 0.293 (which isn't accepted)
Thoughts?
specifically:
Then,
becomes:
Thoughts?
Look at it another way.
Your initial velocity is 29.1.
Figure acceleration against the upward motion.
V2 = 2*a*x
a = 29.12/(2*37) = 11.44 m/s2
Well you know g was 9.8 so you apparently had an additional force that affected a 1.64 m/s2 downward drag.
1.64*.178 = ... oops ... looks like .293N again.
So I am still confused?
Or maybe .293 is correct?
http://dl.getdropbox.com/u/119186/Picture%201.png
Webassign sucks...this is for practice and it gives no feedback as to what we may be doing wrong...
[/URL]
They want -.293 I think. The force is against the direction of motion which is up.
