Optimizing Mass for Vertical Rod Buoyancy in Unknown Fluid
In summary, the conversation discusses a problem involving a rod with a small mass attached to one end, placed in a container of unknown fluid. The rod is able to float vertically with 2/3 of its length submerged and a certain mass in the fluid. The question asks for the maximum and minimum values of the attached mass, and a graph is recommended to show the values of the linear mass density as a function of the mass. Through a discussion of the equations and factors affecting the stability of the rod, it is determined that the minimum value of the attached mass is given by m = (10-3 -0.75λ)/4 and the maximum value is simply 2/8001.
timetraveller123
621
45
A 0.75-m rod has a uniform linear mass density of λ. A small mass m with negligible volume is attached to one end of the rod. The rod with the attached mass is placed in a container of unknown fluid and after oscillating briefly, comes to rest at its equilibrium position. At equilibrium, the rod floats vertically with 2/3 of its length submerged and mass m in the fluid. If the rod were fully submerged it would displace 7.5×10-4 kg of fluid.
(a) What is the maximum value that the mass m can have?
(b) What is the minimum value that the mass m can have?
(c) Sketch a graph that shows the values of λas a function of m
fbuoyancy = g ρ v
fboyant = fweight
g 5 x 10-4 = g (m + 0.75 λ)
how is m supposed to have maximum and minimum values for this equation
Think of the rest position of the rod. Is there a degree of freedom you overlooked ? Make a drawing.
isn't there only one degree of freedom as the question specifies it is vertically aligned and and the mass is at the bottom
My mistake. I thought there was an angle left over, but you are right. In that case I don't see why m isn't fully determined and we're in the same boat :frown:
Maybe we should start calculating m and see where we end up ...:cool:
but we need to know λ for that
Gather the equations - use the symbol ##\lambda##
Oops, I see it's there already. 5 x 10-4 = m + 0.75 λ
Well then all I can think of is a liberal interpretation of 'floats vertically': that it means 'in a vertical plane, but at an angle with the liquid surface'
so how is that supposed to help even if it floats at an angle how are we supposed to calculate the fluid it displaces
I think that stays at 2/3 of the volume of the rod. I was thinking about the of the given 'vertical orientation': if it wants to be stable, there is a condition. Perhaps that sets bounds on m ?
Quite so, it is a question about stability.
@vishnu 73 , suppose the rod is not quite vertical, but at some small angle to the vertical. What relationship between the forces will lead it to rotate towards vertical?
Edit: to clarify, the stability consideration is for finding the minimum value of m. The maximum value is simpler.
Likes BvU
i did what you said but i got the opposite results meaning i got maximum value for when the rod is tilted and minimum value for m when the rod is perfectly vertical my calculation are as follows
when the rod is perfectly vertical:
fb = fweight
5 x 10-4 g = mg + λ 0.75g
5 x 10-4 = m + λ 0.75
5 x 10-4 - λ 0.75 = m this is the minimum value of m
when the rod is tilted i used torque about the point where the rod intersects the water surface = 0
hence,
fb 1/3 L= fweight 1/6 L
2x(5 x 10-4 g) = (mg + λ 0.75g)
10-3 = m + 0.75λ
10-3 - 0.75λ = m this is the maximum value for m i got
did i do something wrong please help!
That is the condition for it to float 2/3 submerged, vertical or not.
hence,
The mass centre of the rod is 1/6 below the surface, but not the mass m.
ah yes forgot about that
so working it out again i got
for tiled rod:
fb = fweight
5 x 10-4(1/3) = (2/3)m + 0.75(1/6)λ
10-3 -0.75λ = 4m
m = (10-3 -0.75λ)/4
is this correct is this lesser than the m for the just floating one
and why is it that the tiled rod can have a lower value for m than the just floating rod.
for tiled rod:
fb = fweight
10-3 -0.75λ = 4m
m = (10-3 -0.75λ)/4
Your equations are right now, but you are not interpreting them correctly.
No, it's not the minimum value of m. It is a relationship between m and λ that must be true, given that it floats 2/3 submerged.
vishnu 73 said:
m = (10-3 -0.75λ)/4
This is the relationship between m and λ when it is borderline whether it will be vertical or not (and if not, it will float horizontally; tilted is unstable).
But you do not care about λ, so combine the two equations to eliminate it.
Similarly, for the maximum value of m, the question wants the absolute maximum over all possible values of λ. This is very easy.
Likes BvU
huh i see what you are saying but when i combine the equations
m = (10-3 -0.75λ)/4
and solving simultaneously i get one solution and not a range for me to find the minimum
i get m = 10-3/(4+5x10-4) this is just 2/8001
and for the maximum value of value the only thing i can think of is λ = 0;
but how that effectively is no rod in which case the m = 5x10-4
is my above working correct ?
i think i have a problem understanding this question the question already specifies the rod is vertical then i don't understand the need for calculating m when it is horizontal please help me explain what the question is asking thanks!
The equations give you the minimum.
That's not what I get. Please check your working. If you still get the same, please post all your steps.
You did not calculate m for being horizontal. Your second equation is for the rod being on the borderline between remaining vertical and falling over. If it does fall over it will go horizontal. There is no stable solution between the two.
sorry my bad about the equation i was careless
i now get m = (10-3 - 5x10-4)/3 = 1/6000
why can't the rod be tilted why must it be vertical or horizontal
i am sorry i still don't get it but why does the above equation get me the minimum value of m
and so is my maximum value in the previous post correct
and if its not too much too ask please walk me through without equation what the is logic behind this entire question that would be very helpful
Yes.
Your second equation says the torque is in perfect balance, that it will be stable at any angle. If m is a fraction more, the net torque will push it towards the vertical, and it will keep going until it gets there. If m is a fraction less, the net torque will push it away from the vertical, and it will keep going until it is horizontal. Note that your equation did not depend on the angle.
Because if m were any less the vertical arrangement would be unstable.
No. It needs to be expressed independently of λ. At what value of m is it impossible for the rod to float 2/3 immersed no matter how small λ is?
Likes timetraveller123
ok now i get the minimum value part but idont understand the maximum value part i don't see how it is supposed to be simpler the best i can do is
m = 5x10-4 - 0.75λ
i don't see you can get rid of the λ
m = 5x10-4 - 0.75λ
What is the smallest possible λ?
is it zero
or wait should i solve the above two equations for λ instead of m
No, it asks for the min and max of m. What is max m if min λ is zero?
5x10-4?
vishnu 73 said:
5x10-4?
Yes.
but i said that on post #15 lol anyways thanks ! for the help
So you did. Sorry, I either missed that or later forgot.
just asking in your own opinion is the question badly phrased ?
It could have been clearer that the min and max values of m were to be over all possible values of λ.
ok thanks
1. What is the purpose of optimizing mass for vertical rod buoyancy in unknown fluid?
The purpose of optimizing mass for vertical rod buoyancy in unknown fluid is to determine the optimal weight of a vertical rod in order to achieve maximum buoyancy in a specific fluid. This is important in various industries such as marine engineering, oil and gas, and underwater exploration where precise buoyancy control is necessary for efficient and safe operations.
2. How is the mass of a vertical rod optimized for buoyancy in unknown fluid?
The mass of a vertical rod can be optimized for buoyancy in unknown fluid through various methods such as mathematical calculations, computer simulations, and physical experiments. These methods involve considering factors such as the density of the fluid, the shape and dimensions of the rod, and the desired buoyancy force.
3. What are the challenges in optimizing mass for vertical rod buoyancy in unknown fluid?
One of the main challenges in optimizing mass for vertical rod buoyancy in unknown fluid is the unpredictability of the fluid's properties. Different fluids have varying densities, viscosities, and other characteristics that can affect the buoyancy of a vertical rod. Additionally, factors such as temperature and pressure can also impact the fluid's behavior, making it difficult to accurately optimize the rod's mass.
4. What are the potential consequences of not optimizing mass for vertical rod buoyancy in unknown fluid?
If the mass of a vertical rod is not optimized for buoyancy in unknown fluid, it can lead to various consequences such as instability and loss of control. An overweight rod can sink too deep, causing damage to equipment or structures, while an underweight rod may not provide enough buoyancy and compromise the safety of operations. It can also result in inefficient use of resources and potential delays in project timelines.
5. How can the optimization of mass for vertical rod buoyancy in unknown fluid benefit industries?
The optimization of mass for vertical rod buoyancy in unknown fluid can benefit industries in several ways. It can improve the overall efficiency and safety of operations, reduce costs by minimizing the need for additional equipment or materials, and increase the lifespan of equipment by preventing damage from excessive buoyancy forces. It can also lead to more accurate and reliable results in various industries such as marine transportation, offshore oil and gas, and underwater construction.
10K
