Calculate Air Flow Force for Piping System Setup
To calculate the force exerted on the block by air flowing through the two holes in the lower pipe, Bernoulli's equation and the conservation of mass principles are applicable. The conservation of mass can be expressed as A1v1 + A2v2 + A3v3 + A4v4 = A5v5, where A represents area and v represents velocity. Bernoulli's equation can also be utilized to relate pressures and velocities at different points in the system, assuming atmospheric pressure at the inlets. To determine the force on the block, one should start at the node where the pipes converge, applying the continuity equation to find flow rates, and then use Bernoulli's equation to calculate pressure drops. The discussion highlights the need to assess whether the airflow is sufficient to generate a lifting force on the block.
bigdads
See attachment for piping system setup.
Question: How much FORCE will the block feel from the air flowing through the two holes in the lower pipe?
I have no idea how to calculate this. Does Bernoulli's equation apply anywhere here?
it looks just like a problem straight out of my fluid mechanics textbook
bernoulli's should apply
and conservation of masses
mass of all inputs - mass of output = total mass change in the system
and for this system
mass in = mass out
So you have 4 inlets & 1 outlet...
Conservation of mass??:
A1v1+A2v2+A3v3+A4v4 = A5v5
unknowns: v1, v2, v3, v4
A=area
v=velocity
Bernoulli??:
P1+P2+P3+P4+(1/2)p(v1^2+v2^2+v3^2+v4^2)+pg(z1+z2+z3+z4) = P5+(1/2)p(v5^2)+pg(z5)
P=pressure
v = velocity
p = density
g = acceleration due to gravity
z = height
Assumptions: P1=P2=P3=P4=atmospheric pressure
2 equations, 4 unknowns...How can this be solved?
How can I use this to get the force on the block?
You're not going to be able to cover the entire network in one swoop. Start at the node where the two pipes meet and apply the continuity equation: Q = Q_1 + Q_2 where the total flow is the flow from the fan. That will give you the two flow rates (a function of the diameters). Now that you have the flow rate at that node, you can now go to Bernoulli and continue back up the pipe to calculate the pressure drop around those holes.
Just out of curiosity, when you say "force on the block" you are referring to a lower pressure that will (I hate to use this term) "suck" on the block? In other words, you want to know if you'll have enough flow to pick up the block?
Yes
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
