Calculate the temperature measured on the resistance scale
To calculate the temperature measured on the resistance scale using the given formula R=R0 (1+ alphaT + betaT^2), one must substitute the constants alpha (3.8 x 10^-3 k^-1) and beta (-3.0 x 10^-6 k^-2) into the equation. The challenge lies in determining the resistance R at 70 degrees Celsius and solving for T. Clarification on the values of alpha and beta was provided, suggesting they are accurate for the calculation. The discussion emphasizes that all necessary information is present to arrive at the solution.
robgb
Thermal physics question...
A wire resistance thermometer is constructed with material that has a resistance that varies as temperature as below.
where constants alpha and beta are 3.8 x 10^-3 k^-1 and -3.0 x 10^-6 k^-2 respectively.
Calculate the temperature measured on the resistance scale at 70 degrees C on the ideal gas scale.
I've got no idea where to start on this one, any ideas?
Thanks, Rob.
I've corrected the values of alpha and beta, does it make more sense now?
I've been told that this question has all the information you need to solve it.
Can anyone help?
Thanks, rob.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
