Calculating Charges q_1, q_2, and q_3 with Integration
The discussion focuses on calculating the charges q_1, q_2, and q_3 using electric flux and integration. Participants emphasize the importance of using the property of electric flux, which states that the total flux through a closed surface is the sum of the individual fluxes from each charge. The equations derived lead to a system of equations that ultimately allows for the determination of the charges. The final conclusion reached is that the charges are 2q, q, and -3q, respectively. This method effectively demonstrates the application of electric flux principles in solving for unknown charges.
kyang002
Question 4
What is the charge q_1?
What is the charge q_2?
What is the charge q_3?
Unsure of which equation to use, and the equations that I am looking at involve integration.
Φ = integral (E * dA) = EA sphere
Φ = q / ε
Can someone teach me how to do this problem?
HINT:Use the property of the electric flux (which is a scalar) of adding wrt the same surface.You'll have to solve a very simple system of equations...
Daniel.
Property of Electric Flux = EA cos theta? But there is no theta. Unsure of the area and of the E.
No.Let be \Phi_{1} the electric flux generated by a charge q_{1} through the (closed) surface S.Similar \Phi_{2} for q_{2} [/itex].Then the total flux is simply the sum of Phi's which,due to the same denominator (epsilon),translates to the charges...
Daniel.
So what is the charge of q_1, q_2, and q_3?
-q/E + (-2q/E) + 3q/E = 0/E = 0
The charge of each is 0?
No,you have to write equations of the type phi_{1}+phi_{2}=phi_{tot} for all 3 surfaces & will end up with an algebraic system of 3 eqn. with 3 unknowns,namely the charges.
Daniel.
Okay, got it. The answers are 2q, q, -3q. Am I correct?
