Calculating Contact Time and Damping Coefficient for a Second Order System
The discussion focuses on calculating the contact time and damping coefficient for a second-order system represented by the equation 2y'' + 4y' + 8y = 8x. The characteristic equation derived from this is 2s² + 4s + 8 = 0, leading to complex roots, indicating a damping ratio of ξ = 0.5. There is a discrepancy noted between the calculated damping coefficient and a book reference stating it is 1, prompting questions about time constants. The discussion clarifies that with complex roots, traditional time constants cannot be defined, as the system will exhibit oscillatory behavior. Overall, the analysis emphasizes the importance of understanding the nature of the roots in determining system characteristics.
huma
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >[/color]
how we can find contact time of second order system ? 2y**+4y*+8y=8x I want to find damping coefficient ... howz possible
huma said:
2y**+4y*+8y=8x
( 2s2 + 4s + 8 ) * y(s) = 8 * x(s)
Finding y(s)/x(s) the characteristic equation of the transfer function will be:
2s2 + 4s + 8 = 0 →
s2 + 2s + 4 = 0
which can be formulated
s2 + 2ξωns + ωn2 = 0
So ωn = 2 , the damping coefficient, ξ = 0.5
2s2 + 4s + 8 = 0 →
s2 + 2s + 4 = 0
actually I got this question from a book of M.handa .I solved my answer are same but the answer given in the book is damping coefficient is 1 ... can you tell me about time constant . how we can find it
The equation
2s2 + 4s + 8 = 0
has two complex roots: s = -1 ± j√3.
If the characteristic equation were to have a damping ratio = 1, it should have two real roots at the same location, for example.
s1 = -1.2 , s2 = -1.2.
In this case the characteristic equation could be written:
s2 + 2.4s + 1.44 = 0
and the transfer function would have a double time constant = 1/1.2 sec.
s2 + 7s + 10 = 0
the two roots would be s1 = -2 , s2 = -5 , and the transfer function would have two time constants:
τ1 = 0.5 sec. , τ2 = 0.2 sec.
When a root is complex, we cannot speak of a "time constant". The time is complex. The system will oscillate within some damping coefficient.
thankyou :)
