Calculating current in circuit with multiple emf's using Kirchhoff's
The discussion revolves around calculating currents I_1, I_2, and I_3 in a circuit using Kirchhoff's Rules after closing a switch. Initial attempts included setting up equations based on Kirchhoff's laws, but the first equation was identified as incorrect, leading to confusion in the calculations. After correcting the equation to I_2 = I_1 + I_3, the user recalculated the currents and found values of I_1 = 72/83 A, I_2 = -51/83 A, and I_3 = -123/83 A. The final solution was achieved by organizing the equations into a matrix format, demonstrating the effectiveness of using a calculator for complex calculations. The discussion highlights the importance of accurate equation setup in circuit analysis.
Spudnik
Find I_1, I_2 and I_3 if the switch, k, is closed using Kirchhoff's Rules.
V=IR
I've had multiple attempts at this and this one is the one that came closest to a solution.
Setting up 3 equations:
1) I_1 = 1_2 + I_3 => I_1 - I_2 - I_3 =0
2) 12V + I_3*(4 Ohm) - I_1*(7 Ohm) = 0
3) 12V - 9V - I_2*(5 Ohm) - I_1*(7 Ohm) = 0
2) 12 = 7*I_1 - 4*I_3 => 12 = 7*(I_2 + I_3) - 4*I_3 => 12 = 7*I_2 + 3*I_3
3) 3 = 7*I_1 + 5*I_2 => 3 = 7*(I_2 + I_3) + 5*I_2 => 3 = 12*I_2 + 7*I_3
Getting rid of I_3:
84 = 49*I_2 + 21*I_3
09 = 36*I_2 + 21*I_3
75 = 13*I_2
I_2 = 5.75
By substituting in, I get
I_1 = -3.7
I_3 = -9.5
Is this anywhere near correct, I don't know why, but somehow this seems fishy to me :S
I think your first equation is not correct. Pay close attention to the direction of the arrows. See how the sum together at either center top node, or center bottom node. You'll find that
I2 = I1 + I3
(not, I1 = I2 + I3 that you originally had.)
[Edit: Oh, and Spudnik, welcome to Physics Forums!]
OK, I redid it with the new formula and I got
I1=0.25
I2=0.25
I3=-2.5625
Clearly this does not fit the initial equation I2=I1+I3
It's strange though because those are the same values I got for I1 and I2 for part A) where it asked for the currents with the switch open...
Double posting because I figured it out:
I1= 72/83 A
I2= -51/83 A
I3= -123/83 A
Using
I2=I1+I3
12+4I3-7I1=0
12-9-5I2-7I1=0
Setting them up for a matrix:
I1 + I2 + I3 = Voltage
+1 -1 +1 =0
-7 +0 +4 =-12
-7 -5 +0 =-3
Letting the calculator do the rest for you: priceless.
