Calculating Energy Dissipation in Free Fall with Drag Force
The discussion revolves around calculating energy dissipation due to drag force on a ball in free fall, specifically when it reaches terminal velocity before hitting the ground. The drag force is defined as bv², where b is the drag coefficient and v is the instantaneous speed of the ball.
  • Participants discuss the relationship between energy dissipation and the equations for potential and kinetic energy, questioning the validity of the equation Ediss=mgh. There is also consideration of conservation of energy principles and the need for height in relation to terminal velocity.
The discussion is active, with participants exploring different interpretations of energy dissipation and the equations involved. Some guidance has been offered regarding the conservation of energy approach, but there is no explicit consensus on the next steps.
There is a noted uncertainty regarding the distance required to reach terminal velocity and how it relates to the overall energy dissipation calculation.
impendingChaos
Need to energy dissipation by the drap force on a ball in free fall from height h and when it has reached terminal speed, assuming it happens before it hits thr ground. Drag force has magnitude bv^2, where b is drag coefficient and v is instantaneous speed of the ball.
I have calculated in an earlier part of the problem that terminal velocity:
Vt=root(mg/b)
Also, isn't the energy dissipation equation:
Ediss=mgh
I have the above equations but am unclear where to move next.
Not sure what you mean by Ediss=mgh. If chosing conservation of energy, one could simply assume that the drag energy(work) is the difference between the final and initial sums of PE and KE. The problem I see, is that the eqn you posted for Vt says nothing about height.
In other words if we knew the distance required to reach terminal velocity, you're home free.
Ok will check that, Ediss is Energy dissipated
thx!
no sweat, either way problem is soluble:
mv'=-b*v^2+mg.
  • · Replies 16 ·
  • · Replies 31 ·
