How Do I Calculate Experimental Error in X-ray Diffraction?
Calculating experimental error in X-ray diffraction involves using Bragg's law to determine atomic spacing, with the angle of maximum intensity as the only variable. The derived equation for spacing is D = A/sin(x), where A is a constant. To find the error, one can introduce new variables and apply differentiation rules, leading to the equation dD = A (dx cos(x))/(sin(x))^2. A significant error value of around 80% was noted, likely due to using degrees instead of radians in calculations. Ensuring the correct unit conversion is crucial for accurate error assessment.
Lemenks
I am writing a lab report for an X-ray diffraction. I have been attempting to come up with an equation for the error using formulas some people from college gave me and also some I found on wikipedia but I am quite sure I am doing it wrong. The only variable is the angle where the maximum intensities are found. I am using Bragg's law to calculate the spacing between the atoms.
D = (N*wavelength)/(2*sin(x))
As there is no error in N, wavelength, or "2", we can let that equal A.
D = A/sin(x)
Some equations I was given:
Z = aX
dZ = adX
Z = X^a
dZ/z = |a|dx/x
Z = SinX
dZ = dX CosX
D = Z = A/sin(x) = A (sin(x))^-1 = A f(y)^-1
I have tried loads of ways of calculating this but I keep getting silly answers. Any help, ideas or links would be really appreciated.
Take it one step at a time. You might find it helpful to introduce new variables. For example, let w=1/sin(x). Then you have ##D = Aw##, so applying your first rule, you have ##\delta D = A \delta w##. (I'm using deltas instead of d because dD looks weird.) Now your job is to find ##\delta w##. If you let ##v=\sin x##, then ##w=1/v = v^{-1}##. Using the second rule, you can find ##\delta w## in terms of ##\delta v##. Then you need to find ##\delta v## in terms of ##\delta x##, and then put it all together.
Hey thanks for the reply, it is very concise and logical, I actually tried that but assumed I must have made a mistake as the value I was getting for the error seemed to large ~80%.
The final equation I have is:
dD = A (dx cosx)/(sinx)^2
This equation seems to give a value for error of about 80%. x ranges from 3 to 35 and dx was 0.1. ie the beam angle ranged from 3 to 35 degree in 0.1 degree steps.
You need to use radians, not degrees. That's probably where the issue lies.
