Calculating final pressure and temperature of cylinder
The discussion focuses on calculating the final pressure and temperature of a cylinder undergoing rapid adiabatic compression with a compression ratio of 15, starting from a pressure of 101.325 kPa and a temperature of 298 K. Participants confirm that the process is adiabatic and utilize the equation P2/P1 = 15 to find P2, resulting in 1519875 Pa. They discuss the relationship between temperature and pressure using the formula T2/T1 = (P2/P1)^((n-1)/n), leading to a calculated final temperature of approximately 381.171 K. The conversation emphasizes algebraic manipulation of equations to isolate pressure and temperature variables, ensuring clarity in the calculations. The final results for pressure and temperature are confirmed through collaborative problem-solving.
mh1985
Using a value of n of 1.1, calculate the final pressure and temperature when the cylinder is compressed rapidly with a compression ratio of 15.
Starting pressure = 101.325 kPa
Starting temp = 298 K
(V2/V1) = 15
Not sure about this part
Rapid compression would mean that the compression is adiabatic. So you also know what other equation?
The compression ratio would be P2/P1=15 and you know what P1 is.
Using the above equation you found and the ideal gas equation, can you form an equation involving only P and T?
Thanks for the reply,
So I multiply both sides of P2/P1=15 by P1 to get P2,
101325 * 15 = P2 = 1519875 Pa
Not sure how to form the equation involving only P & T...
Something like T2/T1 = (P2/P1)^((n-1)/n)
EDIT:
so (P2/P1)^((n-1)/n) = 15^(1.1 - 1)/1.1 = 1.2791
1.2791 = T2/T1
T1*1.2791 = T2 = 381.171 K
Not sure if this is right?
EDIT:
1.2791 = T2/T1
Well you'd have P1Vn1=P2V22 and P1V1/T1 = P2V2/T2
Take the last equation, make V1 the subject and substitute it into the first,the V2 should at least cancel out if I remember correctly.
Hi thanks for the reply
If I make V1 the subject, I get P2V2T1 /P1T2, right so far? :S
But I don't see how to substitute it into the first equation?
P1 * (P2V2T1 /P1T2) = P2V2^2
Sorry, I meant your equation to sub into should be
P1V1n=P2V2n
Just sub your first equation and the volume should cancel out.
P1V1n=P2V2n
So I have:
P1* (P2T1/P1T2)n= V2 ?
mh1985 said:
So I have:
You have
V_1= \frac{P_2 V_2 T_1}{T_2 P_1}
and
P_1V_1^n = P_2V_2^n
so that
P_1 \left( \frac{P_2 V_2 T_1}{T_2 P_1} \right)^n = P_2V_2^n
You can see that V2n is common to both sides and it will cancel out leaving you with only pressure and temperature variables. Thus you can easily get T2 with some simple algebra.
