Calculating Final Temperature Using Ideal Gas Law | Homework Help
To find the final temperature of the gas in the rigid tank after half of it escapes, the ideal gas law equation pV = mRT can be applied to both the initial and final states. The initial conditions include 5 kg of gas at 4 atm and 40°C, while the final pressure is given as 1.5 atm after the mass is reduced to 2.5 kg. The relationship between pressure, volume, and temperature must be maintained, allowing for the calculation of the final temperature using the known quantities. The problem emphasizes understanding how to apply the ideal gas law to different states of the system. The final temperature can be determined once the appropriate values are substituted into the equations.
MastersBound
A rigid tank contains 5 kg of an ideal gas at 4 atm and T=40 deg C. Now, a valve is opened and half of the mass of the gas is allowed to escape. If the final pressure in the tank is 1.5 atm, the final temperature in the tank is?
pV=mRT
I know pV=mRT but I don't know how to use this equation for to different states i.e. beginning and end state.
The equation holds for the two different states, so you have
\begin{align*}
p_i V_i &= m_i R T_i \\
p_f V_f &= m_f R T_f
\end{align*}
What are the quantities you know? What other relationship were you given that relates the quantities?
That is it. That is the whole problem statement. No specific gas or fluid was given.
I know. There's enough information to solve the problem. Those questions were meant for you to answer.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
