Calculating Frictional Work on a Moving Car
  • Thread starter Thread starter preluderacer
    Friction Work
To calculate the work done by friction in slowing a 1000 kg car from 29.8 m/s to rest, the kinetic energy approach is recommended. The kinetic energy equation, 1/2(m)v^2, is used to determine the energy converted to heat, which is essential for this calculation. The correct calculation yields 444,020 J of work done by friction. This method effectively captures the energy loss due to friction without needing the coefficient of friction. The approach and the final answer appear to be accurate.
preluderacer
How much work must be done by frictional forces in slowing a 1000kg car from 29.8m/s to rest?
Im not quite sure how to go about this problem. I know the frictional force is 9800N times the coefficient of friction. And I know the car isn't accelerating prior to slowing down. I am not quite sure how to fit this all together. A little guidance would be greatly appreciated =)
Working with the coefficient of friction is the wrong approach for this. Use an energy approach. How much energy must be converted to heat?
oh I get it I need to use the kinetic energy equation from 28.9 to 0?
I plugged it into the equation 1/2(m)v^2 and solved from 0 to 28.9. My answer was 444020 J. Does this seem like the right method?
Looks good!
