Calculating Power and Energy Consumption in Electrical Circuits
  • Thread starter Thread starter hackeract
    Resistance
The discussion focuses on calculating power and energy consumption in electrical circuits, addressing various questions related to resistance, current, voltage, and capacitance. Key points include the clarification that resistance converts electrical energy into heat, and the calculation of electron flow based on current. The participants also explore potential differences across resistors and equivalent capacitance in series and parallel configurations. Additionally, the implications of using appliances designed for different voltage systems are discussed, emphasizing the risks of using European devices in U.S. outlets. Finally, energy consumption calculations for a refrigerator over 30 days are presented, highlighting the conversion between joules and kilowatt-hours.
hackeract
Alrighty i have some questions, as well as my possible answers. We have a worksheet that i hope to do correctly since the test will be here within a week or so. Anyways ill get to it
1) a resistance irreversibly converts electrical energy into
a) mechanical work
b) chemical energy
c) heat energy
d) potential energy
a and b are out, leaving heat and potential. I am going with D here because energy is LOST as heat, i think to be converted it would have to be conserved. My answer is D)
2. A current of 100 uA flows in a circuit. How many electrons go past a point each second
a) 8.1 x 10^6
b) 4.8 x 10^12
c) 6.2 x 10^14
d) 1.5 x 10^8
I think i could use I = Delta Q/ Delta T.. i have no clue with this one
3) What potential difference is required across a 6.5ohm resistor for a 370 C of charge to flow through it in 2.5 minutes
a) 22v
b) 16v
c) 55v
d) .02v
For this, since we know resistance (6.5 ohm) and Capacitance... I am a little confused, but ide say 6.5 Ohm x 370 C = 2405.. change minutes to seconds, 150seconds, 2405\ 150seconds = 16v... so my answer is B) but that's guesswork.
4)What is the equivant resistance of a 22 ohm, 40 ohm, and a 32 ohm resister connected in series.
a) 85 ohms
b) 94 " "
c) 62 " "
d) 14 " "
Rtotal = R1+R2+R3... so 22+40+32= 94 ohms, my answer is B)
5) Capacitors of 2.5 uF, 6.6 uF, and 10 uF are connected in series, what is their equivalent capacitance.
a) 6.4 uF
b) 1.5 uF
c) 19.1 uF
d) 4.5 uF
capacitors are the same in series.. Ctotal= c1+c2+c3... 2.5+6.6+10 = 19.1 uF my answer is C)
6) Capicitances of 20 uF, 1.8 uF, 5.5 uF, and 10.6 uF are connected in parallel. What is the equivanent capicitance
for these...
1/Ctotal = 1/c1+1/c2+1/c3 (then take the inverse) 1/20+1/1.8+1/5.5+1/10.6 = .88 inverse = 1.13..
7) Appliances in the us are designed to work on 110-120v, where as appliances in europe operate on 220-240v. what would happen if you plugged a european device into u.s outlets without a converter?
a) it would work just not as well as in europe. Its the power rating, not the voltage that matters
b) it would work just not as well as in europe. Its the current rating, not the voltage that matters
c) it would work but overheat and burn up
d) It would barely work since the voltage here is too low to push enough current through the device.
I would say D. If you take a US device to europe it would blow a fuse, so i think it would work just not well at all.
I have a few more, ill post in a couple minutes
a) mechanical work
b) chemical energy
c) heat energy
d) potential energy
No. Since you have eliminated all the other answers, the answer is c. A resistance converts electrical energy into heat.
a) 8.1 x 10^6
b) 4.8 x 10^12
c) 6.2 x 10^14
d) 1.5 x 10^8
One ampere is 1 coulomb per second. One electron = 1.6e-19 C. or 1 C = 6.2e18 e. How many electrons in 100e-6 C.?
a) 22v
b) 16v
c) 55v
d) .02v
Capacitance?? The C is coulombs. I is the current in coulombs/sec. What is the expression for I in terms of V and R? What is the current if 370 C. flow in 150 seconds?
a) 6.4 uF
b) 1.5 uF
c) 19.1 uF
d) 4.5 uF
Capacitors in series are added like resistors in parallel.
for these...
.. this was the approach needed for ques. 5. and your approach in 5 is needed here.
Since I = V/R, if you have half the voltage you will have half the current.
AM
new Q...
A fridge uses 600w when running and operates 8.4 hours each day
a) how much energy in joules, does it use in 30 days?
b) what will it cost to operate for 30 days if it costs 8.3 cents/KwH
New questions should preferably go into new threads so that they can be referenced more easily.
Define power. After that everything should become clear.
ok well P = IV, P = V2 / r..
power is equal to a watt which equals a Joule/Second
600w equals 600 j/s if it goes 8.4 hours it would be 8 hours (60 minutes)+ 24 minutes (for the .4 hours) so that's 504 minutes every day, x 30 days equals 15120 minutes in 30 days. Now convert minutes to seconds, there's 60 seconds in one minute so 15120x60 = 907200 seconds in 30 days @ 8.4 hours a day. Now we have to get seconds to cancel,
600 j/s x 907200 seconds = 544320000 Joules in 30 days @ 8.4 hours a day
i think i did that right for part A
Yup, your first part is correct. The only definition you need is power = energy over time (or, the rate of energy gain or loss).
For the second part, you should know that kWh (kilowatt-hour) is actually a unit of energy that electric companies often use in order to work out your utilities bill. You're charged by number of kWh you use every month.
1 kWh = 1kW * 1 hour. Recall that energy = power * time, so this form is expected.
Now work out how much energy that fridge consumes in kWh (instead of joules), and you should get the answer. Keep track of your units and let them cancel one another out.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
