Calculating RMS and Peak Values of Electric Fire
The discussion revolves around calculating the RMS and peak values for a one-bar electric fire rated at 1000W with an RMS voltage of 240V. The RMS current is calculated using the formula RMS Power = RMS Voltage * RMS Current, resulting in an RMS current of approximately 4.167A. The peak voltage is derived as 339.4V, and the peak current is calculated to be about 5.893A. The conversation also touches on the nature of the electric fire, clarifying that if it operates as a purely resistive load, the voltage and current are in phase. The calculations provided are confirmed to be correct, and further questions are welcomed.
suf7
A one bar electric fire has a power rating of 1000W (1kW). If the RMS voltage of the mains is 240V, find the RMS value of the current flowing in the fire and the peak values of current and voltage?
Can some one please help me??..Its a past exam question and i don't even know how to start it??..What do i do??
What is a "one bar electric fire"? The answer depends on the power factor of the circuit. If it is just a resistive heater, the voltage and the current are in phase, and the calculation of current is simple ohms law. The power would just be P = IV
SOLUTION HINTS:
This problem is designed to distinguish between RMS and Peak values of Voltage, Current, and Power for a purely resistive load. We are given:
{RMS Voltage} = (240 V)
{RMS Power Rating for Resistive Load} = (1000 W)
For standard AC systems, we know that:
{RMS Power} = {RMS Voltage}*{RMS Current}
Thus, we can solve for {RMS Current}:
{RMS Current} = {RMS Power}/{RMS Voltage} = (1000 W)/(240 V)
Also for standard AC systems:
{Peak Voltage} = √2{RMS Voltage} = (1.414)*{RMS Voltage}
{Peak Current} = √2{RMS Current} = (1.414)*{RMS Current}
{Peak Power} = {Peak Voltage}*{Peak Current} =
= √2{RMS Voltage}*√2{RMS Current} =
= (2)*{RMS Voltage}*{RMS Current}
::: ⇒ {Peak Power} = (2)*{RMS Power}
Use above basic information to determine required solutions to this problem.
xanthym said:
SOLUTION HINTS:
Thanks ALOT!..Using your help i worked out the following:
{RMS Current} = 4.167A
{Peak Voltage} = 339.4V
{Peak Current} = 5.893A
Do these values seem ok?...If they are ok could i ask another question??..it carries on from the question I've already asked?
Thanks
Sorry i don't quite understand what you mean??
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
