Calculating the magnitude of the net force bewteen charges
The problem involves calculating the net force experienced by a charged ball in a symmetric arrangement of multiple point charges. The specific charges and their configurations are provided, with a focus on understanding the interactions between these charges.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of forces between the -3Q charge and other charges, including how to account for diagonal forces and the use of superposition. Questions arise about the net force in specific configurations and the reasoning behind the expected outcomes.
Some participants are exploring the implications of diagonal forces and whether they cancel out, while others are questioning the assumptions about net forces in specific columns of charges. Guidance on using superposition has been offered, with acknowledgment of the need to consider both x and y components of the forces.
Participants are working within the constraints of a homework assignment, which may limit the information available for calculations and the assumptions that can be made about the system.
thrills4ever
Nine different charged balls, which we treat as point charges, are arranged in a highly symmetric pattern around a square. Note that the value of Q is 4.00 x 10-6C, and L = 30.0 cm
Image: http://www.webassign.net/userimages/81224?db=v4net
1) What is the magnitude of the net force experienced by the ball with the -3Q charge due to the +3Q and +Q charged balls only?
2) What is the magnitude of the net force experienced by the ball with the -3Q charge due to the four charged balls with charges of -5Q?
3 )What is the magnitude of the net force experienced by the ball with the -3Q charge due to the two charged balls with charges of +2Q?
4) Use your previous three results to find the magnitude of the net force experienced by the ball with the -3Q charge due to the other 8 charged balls.
1) I got this part correct: I understand how to solve for the force when the point charges are in the straight line
My work is as follows:
F3 = F31 + F32
= k(-3Q)(Q) / L^2 + k(3Q)(+3Q) / 4L^2
= 5.25k(Q)^2 / L^2
= 8.39
2) and 3) :
Here is where I do not understand how to solve for the force when there are diagonals involved.
If I am correct in my thinking for 2) then does the -3Q ball experience 2 diagonal forces from the 2 left -5Q balls and a straight force to the right from the 2 right -5Q balls?
In my calculation I did F53 = 15kq^2 / 3L^2, simplifying to 5kq^2 / L^2 which gives me 7.99 I believe. Since there are essentially 2 diagonal forces, do I multiply this by 2 and then add the other force which is directed right by doing 7.99cos(30 degrees)?
Thanks for all the input!
The first part of your reasoning is right.
But consider only the right most column. If we consider this column by itself, why do you think there would be a net force?
well i tried putting in 0 for the answer and it did not work because I initially thought the opposing diagonals cancel each other out, but apparently that is not the case.
Sorry I meant right, why do you think there would be a force on the right most column?
The two 5q balls on the left do give you a net force that is horizontal -- which can be easily seen if you componentize the forces and use superposition.
Sorry for the mix up.
I see what you mean..im not sure how to use superposition in this case since both the forces from the two 5q balls on the left are in opposing diagonals. So the resultant force is directed to the right horizontally correct? I tried finding the F53x and F53y components but i think that both diagonals produced y components that cancel each other out. I am not sure how to proceed with the question.
The principal of superposition basically means that the total force is the sum of the forces. You are correct and finding that the y-component of the two balls will cancel out since they are equal and opposite, however you're still left with the x-components.
  • · Replies 21 ·
