Derivative of Hyperbolic Trigonometric Function
gurtaj
derivative of (e^x-e^-x)/(e^x+e^-x)
This answer was marked 2/4 on the test, can anyone help me get the right answer please ?
Hi gurtaj! :smile:
I don't understand your first step: you have (e^x-e^{-x})(e^x+e^{-x})^{-1} and you wish to derive it. The product rule says that this equals
(e^x-e^{-x})^\prime(e^x+e^{-x})^{-1}+(e^x-e^{-x})((e^x+e^{-x})^{-1})^\prime
You did the second part of the sum allright, but you didn't differentiate anything in the first part of the sum...
oh sorry the next step after
I meant to put
(e^x+e^{-x}) (e^x+e^{-x})^{-1} + (e^x-e^{-x})(-1)(e^x+e^{-x})^{-2}(e^x-e^{-x})
so i did
derivative of the first one times second , then derivative of the second one times first
OK, so that expression will evaluate easily to the answer...
i think that is right too but somehow it was marked 2/4, and the teacher wrote expand and simplify
Yes, the final answer is correct. But if I was your teacher I would have given 2/4 too. The point is that your notation is really messy and you can't really see what you're doing :frown: And you're making the problem longer than it needs to be...
Quotient rule will greatly simplify your answer, and be much cleaner.
The teacher didn't cut 2 marks for messy notations or making the problem longer, she said its the answer that's wrong. She said you can expand that answer even more
I tried Quotient rule and end up with same answer
(e^x-e^{-x})/(e^x+e^{-x})
(e^x+e^{-x}) (e^x+e^{-x})-(e^x-e^{-x})(e^x-e^{-x})/ (e^x+e^{-x})^{2}
1-((e^x-e^{-x})^{2}/ (e^x+e^{-x})^{2})
Then I guess your teacher wants you to simplify your answer. Put your fractions on one denominator and work out the squares...
A bit silly to subtract points for that, unless she stated that your answer must be simplified...
Ohhhh, I see what's going on here.
Hint: Look and sinh and cosh.
You still the problem right though. I can't see why your teacher would give you half credit.
(Also, look at tanh)
We never learned Hyperbolic function, so she wasn't expecting that from us
I have no idea then. I think your instructor's crazy.
I second that! :smile:
