Center of mass and integrating
flame_m13
A solid "rough" of constant density (\delta =1) is bounded below by the surface z=4y^2,above by the plane z=4, and one the ends by the planes x=1 and x=-1. Find the center of mass...
_{M}xy =\int\int\int z \delta dV
Mass = \int\int\int\deltadV
then to find the center of mass, the z component would be _{M}xy / M
_{M}xy = \int\int\int^{4}_{4y^2} z \deltadzdydx
=\int\int [z^2/2]^{4}_{4y^2}dydx
=\int^{1}_{-1}\int^{1}_{0}(8-8y^4)dydx
=8\int^{1}_{-1}[y-y^5/5]^{1}_{0} dx =8\int^{1}_{-1}[4/5]dx
=8[4x/5]^{1}_{-1} = 8[4/5+4/5]= 64/5
For some reason, and it isn't obvious to me why, the solution manual says that this answer should be 128/5. I'm off by a factor of 2, but i don't know what i did wrong. I haven't attempted to find the mass yet, but i think once i understand what I did wrong here, that answer shouldn't be hard to find.
Why are you integrating, with respect to y, from y= 0 to y= 1? The "cylinder" z= 4y2 intersects the plane z= 4 at y= -1 and 1.
i don't know why that didn't register with me. thanks for pointing that out. my answer is now 128/5, the same as the book's.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
